Drear all,
I'm suppose to design and implement Microcontroller-based secured wireless data transmitter & receiver device.
As a beginner in this field I face some problem, and the are some Q. needs to be answered.
Note: the algorithm that I'm going to use is AES.
The project idea is :
- A transmitter that receive the data from the PC through the USB port , then inside the transmitter the data get encrypted by the Algorithm witch burned in the micro controller , after that the data get transmitted.
- the second part is the receiver part the data get received then get decryption process then send to the receiver computer.
- My first Q is " Is it possible to implement like that project?
- second : What components going to be used for each part of the projects?
- Is it possible to burn the algorithm source code in in the micro controller.
- if possible what type of micro controller shall I use? ( the one that have the largest ROM & RAM ).
- how can I interface the PC using USB to the transmitter & receiver?
- What Freq. shall I use in project.
If any body know any think about the project parts or have been read a similar project plz help me.
I hope that I can get an answer for the hole or parts of the Qs.
I'll be relay thankful for all.
