Microcontroller and possible compatible replacements.
Discussion in 'Programmer's Corner' started by ron roberts, Jan 25, 2010.
  1. ron roberts
    Thread Starter Active Member
    May 7, 2008
    49
    Hi all.
    Is there a replacement microcontroller PIC16f84?
    I have loads of useful programs\HEX\ source code files that I would like to continue using; the only problem is the PIC16f84 is now obsolete.
  2. S_lannan
    Jun 20, 2007
    247
  3. Papabravo
    Feb 24, 2006
    10,340
    1,850
    The PIC16F628 provides an upgrade path and is cheaper with more capabilities. You will have to reassemble and change the config switches.
  4. delmasli
    Sep 17, 2009
    17
    I agreee to Papabravo,
    16F628 or 16F628A are the best replacements for 16F84. And also it is much more easy to find these ICs in the market than 16F84.
