microcontroller 68hc12 homework. Can you please help me understand the concept?
Discussion in 'Homework Help' started by rohitaudipudi, Feb 28, 2010.
  1. rohitaudipudi
    Feb 28, 2010
    MicroController Questions. Can you help me understand?
    (1) Write an assembly program to subtract the hex numbers $16753284 from $98765432.
    (2) Write a program to subtract the hex numbers stored at $804~$807 from the hex number
    stored at $800~$803, and save the difference at $900~$903.
    (3) Write an instruction sequence to divide the signed 16-bit number stored at memory locations
    $805~$806 by the 16-bit unsigned number stored at memory locations $820~$821, and store the
    quotient and remainder at $900~$901 and $902~$903, respectively.
    (4) Since there is no 32-bit by 32-bit multiplication instructions, we will have to break a
    32-bit number into two 16-bit halves and use the 16-bit by 16-bit multiply instruction to
    synthesize the operation. Assume M and N are the multiplicand and the multiplier, respectively.
    These two numbers can be broken down as follows:
    M = MHML
    N = NHNL
    where, MH and NH are the upper 16 bits and ML and NL are the lower 16 bits of M and N,
    respectively. Write a procedure to multiply two unsigned 32 bit numbers. (No need to write
    assembly language).
    (6) What are the new values of the memory location at $800 and the C flag after executing the
    instruction ASR $800? Assume that the memory location $800 originally contains the value
    of $ED and the C flag is 0.
    (7) Compute the new values of accumulator B and the C flag after executing the instruction
    ROLB. Assume the original value of B is $BD and C flag is 1.
    (8) Write a procedure followed by an assembly program to count the number of zeros contained
    in memory locations $800~$801 and save the result at memory location $805.
    Hint: The logical shift right instruction is available for double accumulator D. We can load
    this 16-bit value into D and shift it to the right sixteen times or until it becomes zero.
    (9) Write an instruction sequence to create a 100-ms time delay.
    (10) What is the delay that the following program creates?
    ldab #100
    out_loop ldx #20000
    inner_loop psha
    pula
    psha
    pula
    psha
    pula
    psha
    pula
    psha
    pula
    psha
    pula
    psha
    pula
    psha
    pula
    psha
    pula
    nop
    nop
    dbne x,inner_loop
    dbne b,out_loop
  2. jlcstrat
    Jun 19, 2009
    58
    Is there a specific part you're having problems with?
  3. rohitaudipudi
    Feb 28, 2010
    Yes Sir. I would like to know how to start with, like 32 bit multiplications. how do you think in the perspective and how do you start with. how do u share registers. please explain . thank you!
  4. jlcstrat
    Jun 19, 2009
    58
    For assembly, you have to go simple step by step. It looks like you just need a flow chart for the multiplication. Best thing to do is write it the exact way you would do it by hand. Leave out no steps, such as carries.
