1. ht systems
    Aug 2, 2011
    71
    hello there , does anyone have a pdf file contain explaining how to use pic16f630 or 16f628 .... etc ?
  2. bertus
    Administrator
    Apr 5, 2008
    15,809
    2,390
  3. ErnieM
    Apr 24, 2011
    7,447
    1,628
    I would expect smeone with any expierence with these parts to know where Microchip has information. "How to use" leads me to thing you need more then just the data sheet, is that so?
  4. t06afre
    May 11, 2009
    5,939
    1,222
  5. ht systems
    Aug 2, 2011
    71
    i worked in microchip but im generating codes using flowcode but its not working at all , im the simulation its working and im sure that the circuit is right , anyone know the answer about that ?
  6. ErnieM
    Apr 24, 2011
    7,447
    1,628
    The good news it is sims. My general rule is "if it don't sim you ain't gonna win." so you're off to a good start.
    I don't know anything about flowcode. How does it simulate the code? Do you run it back thru MPLAB or something else?
    It does sound like you may have a circuit problem, can you post your schematic? Post it's assembly output too, we may be able to spot a configuration setting problem or such.
  7. ht systems
    Aug 2, 2011
    71
    flowcode is a program to design microchip circuit and it generating c code
  8. nigelwright7557
    May 10, 2008
    488
    71
    With the PIC its a matter of flogging your way through the datasheet carefully.
    Its amazing that sometimes code doesnt work because of a bit in a register somewhere that is buried in the datasheet. This even applies to the simplest PIC's.
