Microchip RN4020 Bluetooth LE
joeyd999
Joined Jun 6, 2011
5,283
BTW, this is turning into the hardest thing I've ever done. But only because the documentation absolutely sucks. And I have to discover things (things which should be clearly documented) along the way...
joeyd999
Joined Jun 6, 2011
5,283
Here's where the code stands now. If you look at state bts2, you'll see that there is actually a "sub" state machine running within the main state machine. I did this because I found that, often, a series of commands must be sent, each requiring an 'AOK' response. So I just gathered them all into one state of the main machine.
Code:
;Bluetooth Flags
#define    fbtinit    btflag0,0,1        ;1=bluetooth initialized
;#define     btflag0,1,1        ;
;#define     btflag0,2,1        ;
;#define     btflag0,3,1        ;
;#define     btflag0,4,1        ;
;#define     btflag0,5,1        ;
;#define     btflag0,6,1        ;
;#define     btflag0,7,1        ;
;standard response flags
#define    FSRAOK    btsresp,0,1        ;"AOK"
#define    FSRERR    btsresp,1,1        ;"ERR"
#define    FSRBOND    btsresp,2,1        ;"BONDED"
#define    FSRSEC    btsresp,3,1        ;"SECURED"
#define    FSRCEND    btsresp,4,1        ;"CONNECTION END"
#define    FSRRBT    btsresp,5,1        ;"REBOOT"
#define FSRZCMD    btsresp,6,1        ;"\0CMD" (reply when reboot complete)
#define    FSRCON    btsresp,7,1        ;"Connected"
#define    FSRNSR    btsresp+1,0,1        ;non-standard response received
;#define     btsresp+1,1,1        ;
;#define     btsresp+1,2,1        ;
;#define     btsresp+1,3,1        ;
;#define     btsresp+1,4,1        ;
;#define     btsresp+1,5,1        ;
;#define     btsresp+1,6,1        ;
;#define     btsresp+1,7,1        ;
;wait for standard response flags
#define    FWRAOK    btswait,0,1        ;"AOK"
#define    FWRERR    btswait,1,1        ;"ERR"
#define    FWRBOND    btswait,2,1        ;"Bonded"
#define    FWRSEC    btswait,3,1        ;"Secured"
#define    FWRCEND    btswait,4,1        ;"Connection End"
#define    FWRRBT    btswait,5,1        ;"Reboot"
#define FWRZCMD    btswait,6,1        ;"\0CMD" (reply when reboot complete)
#define    FWRCON    btswait,7,1        ;"Connected"
#define    FWRNSR    btswait+1,0,1        ;non-standard response received
;#define    btswait+1,1,1        ;
;#define    btswait+1,2,1        ;
;#define    btswait+1,3,1        ;
;#define    btswait+1,4,1        ;
;#define    btswait+1,5,1        ;
;#define    btswait+1,6,1        ;
;#define    btswait+1,7,1        ;
Code:
;** BTININT -- Initialize Bluetooth **
initbt
    BANKSEL    btstate            ;select bluetooth working bank
    bsf    wakesw            ;wake bluetooth
    bsf    wakehw
    bra    ibtex            ;exit restoring bank
;** BTPRCV -- Process Bluetooth receiver**
;**   return z if no response           **
btprcv    retbc    fbtinit            ;don't receive if in initialzation
    movlf    fsr1h,high btrcvbuff    ;point to receiver buffer
    movff    btrhead,fsr1l        ;  and index to next character
btplp    rcall    rxbyte            ;receiver byte available?
    retz                ; z if none
    movwf    indf1            ;save character at current position
    movlw    '\r'            ;ignore return characters
    cpfseq    indf1
    movf    postinc1,w        ;get back in w, and update pointer
    movff    fsr1l,btrhead        ;save new head position
    xorlw    '\n'            ;new character a line feed?
    bnz    btplp            ;no, get some more characters, if available
    movlfb    btrhead,low btrcvbuff    ;reset btrhead for next message
;parse for common messages
;if common response not matched, indicate (likely) parameters returned from RN4020
    bsf    btsresp,0,1        ;set 1st bit in standard response flags
    movdf    tblptr,btcmes        ;tblptr -> possible responses (\n separated, \r terminated)
btplp0    lfsr    0,btrcvbuff        ;fsr0 -> point to head of response buffer
btplp1    tblrd    *+            ;get next character from list of responses
    movlw    '\r'            ;\r is response list terminating character
    xorwf    tablat,w        ;  end of response list?
    bz    btpnmf            ;yes, no response matched
    movf    tablat,w        ;get character
    cpfseq    postinc0        ;test against charcter in response buffer
    bra    btpnom            ;!= means no match, skip to next response
    xorlw    '\n'            ;new line character?
    bz    btpmat            ;yes, we have found a match
    bra    btplp1            ;keep testing characters till match
;no match of current response, skip ahead till /n or /r
btpnom    clrc                ;roll to next response
    rlcf    btsresp,f,1
    rlcf    btsresp+1,f,1
btplp2    tblrd    *+            ;get next character from list of responses
    movlw    '\r'            ;get terminating character
    movlw    '\n'            ;is it a new line character?
    xorwf    tablat,w
    bnz    btplp2            ;loop till \0 or \n
    bra    btplp0            ;and test against next response
;match found, response bit set
btpmat
;match not found, non-standard response bit set
btpnmf    clrz                ;nz indicates a new reponse has been received
    return
btcmes    db    "AOK\n","ERR\n","Bonded\n","Secured\n","Connection End\n","Reboot\n","\x00CMD\n","Connected\n",'\r'
;** POLLBT -- Bluetooth polling -- called each main loop pass **
pollbt
    clrf    btsresp,1        ;clear standard response flags
    clrf    btsresp+1,1
    rcall    btprcv            ;check to see if a new bluetooth response has been received.
    bz    pbtnrsp            ;no response
;a response has been received from bluetooth
    movf    btswait,w,1        ;are we waiting for a particular response?
    iorwf    btswait+1,w,1
    bz    pbstate            ;no, just process machine
;decide whether or not to throw an error
    bbs    fwrerr,pbteok        ;is ERR an acceptable response?
    bbs    fsrerr,pbterr        ;No, flag ERR as error.
pbteok    movf    btswait,w,1        ;are we waiting for a response?
    andwf    btsresp,w,1        ;has a proper response been received?
    bnz    pbstate            ;yes, process state machine
    movf    btswait+1,w,1        ;again, next byte
    andwf    btsresp+1,w,1
    bnz    pbstate
    bra    pbtimp            ;flag an improper response
;no response received from bluetooth this pass -- process timed functions
pbtnrsp    movf    btstime,f,1        ;is timer running?
    bz    pbtntim            ;no, not a timed function
;timed function -- either response time-out or timed state
    btfsc    tc16ms            ;process 16ms timer
    decfsz    btstime,f,1        ;decrement state timer
    bra    ibtex            ;no further processing if timer not expired
    iorwf    btswait+1,w,1
    bz    pbstate            ;no, just process timed state after delay
;otherwise, flag a timeout error
    bra    pbtrto            ;show timeout error
;not a timed function
pbtntim    movf    btswait,w,1        ;are we waiting for a particular response?
    iorwf    btswait+1,w,1
    bra    ibtex            ;or wait until timer expires
;Handle improper response
pbtimp    bra    ibtex            ;ignore improper responses (for now)
;Handle ERR response
pbterr    movlb    0
    movlw    bterr            ;get ERR error code
    call    seterr            ;and show error
    bra    ibtex            ;ignore erroneous responses
;Handle timeout during reception of response
pbtrto    movlb    0
    movlw    btrto            ;get time out error code
    call    seterr            ;and set error limp along
;process Bluetooth state machine
pbstate    clrf    btswait,1        ;clear waiting flags for next pass
    clrf    btstime,1        ;and state timer
    movfw    btstate
    call    cjump
    bra    bts0            ;state 0:  await BTAWAKE hardware line
    bra    bts1            ;state 1:  send feature string
    bra    bts2            ;state 2:  setup and reboot
    bra    bts3            ;state 4:  wait for reboot to complete
    bra    bts4            ;state 5:  start advertising
    bra    bts5            ;state 6:  await connection
    bra    bts6            ;state 7:  await disconnection
;** Bluetooth states  **
;-- State 0:  await BTAWAKE hardware line, then wait 100ms
bts0    bbc    btawake,ibtex            ;exit if BTAWAKE not asserted
    movlfb    btstime,clctim(t16ms,115)    ;set up 100 ms timer
    bra    ibtns                ;and get out
;-- State 1: clear receive buffer, then send feature string
bts1    call    rxbyte                ;data in receive buffer?
    bnz    bts1                ;yes, keep reading till clear
    bsf    fbtinit                ;indicate initialized
    txpstr    sbtfs                ;send feature settings string
    bra    ibtexat
;-- State 2: setup prior and reboot
bts2    movfw    btssubst            ;get substate counter
    call    cjump
    bra    bts2a                ;set friendly name
    bra    bts2b                ;set model
    bra    bts2c                ;set manufacturer name
    bra    bts2d                ;clear private services
    bra    bts2e                ;set server services
    bra    bts2f                ;set private service UUID
    bra    bts2g                ;set private service characteristics
    bra    bts2h                ;reboot
bts2a    txpstr    sbtfn                ;set friendly name
    bra    ibssx
bts2b    txpstr    sbtmod                ;set model name
    bra    ibssx
bts2c    txpstr    sbtmnm                ;set manufacturer name
    bra    ibssx
bts2d    txpstr    sbtcps                ;clear private services
    bra    ibssx
bts2e    txpstr    sbtstsrv            ;set server services
    bra    ibssx
bts2f    txpstr    sbtpsuid            ;set private service UUID
    bra    ibssx
bts2g    txpstr    sbtpscar            ;set private service characteristic
    bra    ibssx                ;  and index to next state
bts2h    txpstr    sbtres                ;send reset
    bsf    fwrrbt                ;wait for 'Reboot'
    bra    ibtext
;-- State 3: wait up to 3,200 ms for reboot sequence
bts3    bsf    fwrzcmd                ;wait for '\0CMD'
    movlfb    btstime,clctim(t16ms,3212)    ;up to 3212ms allowed for response
    bra    ibtns
;-- State 4: start advertisement
bts4    movlb    0
    call    bloff                ;turn off for disconnected
    txpstr    sbtadv                ;send start advertisement
    bra    ibtexae                ;and allow ERR in case already advertising
;-- State 5:  await connection
bts5    bsf    FWRCON                ;await connection
    bra    ibtns
;-- State 6:  await disconnection
bts6    movlb    0
    call    blon                ;turn on backlight to show we are connected
    bsf    FWRCEND                ;await disconnection
    movlfb    btstate,4            ;restart advertisement when disconnected
    bra    ibtex
;set up next state with AOK/ERR response and 200ms timeout
ibtexae    bsf    FWRERR                ;wait for 'ERR'
;set up next state with AOK response and 200ms timeout
ibtexat    bsf    FWRAOK                ;wait for 'AOK'
;set up next state with 200 ms timeout
ibtext    movlfb    btstime,clctim(t16ms,213)    ;up to 213ms allowed for response
;set up next state
ibtns    incf    btstate,f,1            ;and skip to next state on completion
;restore BSR and quit till next pass
ibtex    movlb    0
    return
;set up next substate with AOK, and 200ms
ibssx    bsf    FWRAOK                ;wait for 'AOK'
    incf    btssubst,f,1            ;go to next substate
    movlb    0                ;restore bsr
    return                    ;and get out
;** Strings **
sbtfg    db    "gr\r\0"            ;get features
sbtfs    db    "sr,00060000\r\0"        ;no auto-advertise, no authentication
sbtfn    db    "s-,WECoyote\r\0"        ;set friendly name
sbtmod    db    "sdm,AAC1000\r\0"        ;set model
sbtmnm    db    "sdn,Acme Products\r\0"        ;set manufacturer name
sbtres    db    "r,1\r\0"            ;reset
sbtadv    db    "A\r\0"                ;advertise
sbtunb    db    "U\r\0"                ;unbond
sbtcps    db    "PZ\r\0"                    ;clear private services
sbtstsrv db    "SS,40000001\r\0"                ;allow private services
sbtpsuid db    "PS,1000EEE0000000000000000000000000\r\0"    ;set private service UUID
sbtpscar db    "PC,1000EEE1000000000000000000000000,02,06\r\0"    ;add private service characteristic UUID
joeyd999
Joined Jun 6, 2011
5,283
And here's a ram dump for the above code:
Edit: 0x600 is the EUSART receive buffer, 0x700 is the transmit buffer. The command is transmitted first, followed by a received response.
joeyd999
Joined Jun 6, 2011
5,283
What I want to know is what genius at Microchip thought is was a good idea to 'talk' to a chip in English?
Ok, so it makes it easy to communicate via terminal for development...but, dammit (!) give me a mode where I can switch it to talk binary.
GopherT
Joined Nov 23, 2012
8,009
I'm happy to know its here when I need it. I have an HC-06 from eBay that seems to operate with similar commands.
I was going to make a comment about the ASM vs C but I knew that was like trying to talk my kids into eating candy instead of vegetables... Whoa, wait a minute. I think I got that right but.. Never mind.
joeyd999
Joined Jun 6, 2011
5,283
Ok...I can now parse non-standard responses. Code below. There is only one non-standard response right now -- "ConnParam:'. It's easy to add more and are enumerated according to the list at btnsmes. Once a non-standard response is found, a jump table is then used to determine how many, and what kind, of arguments to capture. In this case, it is 3 <hex16>s, in the format of 0123,4567,89AB.
BTW, some responses include a space between the response and the arguments, other's don't. And some responses are only arguments with no contextual text. This chip is annoying...
I am not sure if anyone noticed, but I use a few macros here and there to make coding easier. I haven't published those. So, if you see a weird mnemonic, it's a macro. Sorry.
Oh, and the private characteristic setup is commented out. I cannot figure out what is wrong with nRF. I've even managed to crash my Android a few times. The issue is definitely with the app, not my code. Really.
Code:
initbt
    bsf    wakehw
    retz                ; z if none
    cpfseq    indf1
    movdf    tblptr,btsmes        ;tblptr -> possible standard responses (\n separated, \r terminated)
    xorwf    tablat,w
    rlcf    btsresp,f,1
    rlcf    btsresp+1,f,1
    xorwf    tablat,w
btpmat
    return
;standard response messages -- list is \r terminated (so we can include 0x00 for reboot)
btsmes    db    "AOK\n","ERR\n","Bonded\n","Secured\n","Connection End\n","Reboot\n","\x00CMD\n","Connected\n","NFail\n",'\r'
pollbt
    clrf    btsresp+1,1
    iorwf    btswait+1,w,1
    andwf    btsresp+1,w,1
    bnz    pbstate
    iorwf    btswait+1,w,1
    iorwf    btswait+1,w,1
    bz    pbstate            ;no, just process the untimed state
    bra    ibtex            ;otherwise, just wait until response
pbtimp    btfsc    fsrnsr            ;non-standard response?
    rcall    btpnsr            ;go parse it
pbterr    movlb    0
pbtrto    movlb    0
    movfw    btstate
    call    cjump
    bra    ibtexat
    call    cjump
;    bra    bts2e                ;set server services
;    bra    bts2f                ;set private service UUID
;    bra    bts2g                ;set private service characteristics
    bra    bts2ga                ;unbond
    bra    bts2h                ;reboot
    bra    ibssx
    bra    ibssx
    bra    ibssx
    bra    ibssx
    bra    ibssx
    bra    ibssx
bts2ga    txpstr    sbtunb                ;unbond
    bsf    FWRERR                ;'ERR' is ok if not bonded
    bra    ibtext
    bra    ibtns
bts4    movlb    0
    bra    ibtns
bts6    movlb    0
    bra    ibtex
;set up next state
ibtex    movlb    0
    return
    return                    ;and get out
;** Strings **
;** BTPNSR -- Parse Non-Standard Responses **
btpnsr    clrf    bitcnt            ;use bitcnt as index to received response
    movdf    tblptr,btnsmes        ;tblptr -> possible non-standard responses (\n separated, \0 terminated)
btpnlp0    lfsr    0,btrcvbuff        ;fsr0 -> point to head of response buffer
btpnlp1    tblrd    *+            ;get next character from list of responses
    movf    tablat,w        ;get character from list
    bz    btpnnf            ;z=end of list, not found
    movlw    '\n'            ;== \n means we have a match!
    xorwf    tablat,w
    bz    btpnm            ;go process for arguments
    cpfseq    postinc0        ;compare with received
    bra    btpnnm            ;no match, skip to next response
    bra    btpnlp1            ;continue till match/no match
;no match of current response, skip ahead till /0 or /n
btpnnm    incf    bitcnt,f        ;update response counter
btpnlp2    tblrd    *+            ;get next character from list of responses
    bz    btpnnf            ;z=end of list -- no match
    xorlw    '\n'            ;is it a new line character?
    bnz    btpnlp2            ;loop till \0 or \n
    bra    btpnlp0            ;and test against next non-standard response
;no match found - what do we do?
btpnnf    return                ;for now, just ignore the response
;match found -- bit count has response number
btpnm    movfw    bitcnt            ;get response number
    call    cjump            ;and process it
    bra    btnscp            ;'ConnParam:'
;ConnParam <hex16>,<hex16>,<hex16> (connection interval, slave latency, supervison timeout)
btnscp    lfsr    1,conint+1        ;point to holders
    rcall    hex2bin            ;capture interval
    rcall    hex2bin            ;capture slave latency
    rcall    hex2bin            ;capture supervision timeout
    return
;non-standard responses -- list is \n separated, \0 terminated
btnsmes    db    "ConnParam:\n",0
;** HEX2BIN -- Convert arbitrary length hex to binary        **
;**   store result at fsr1 -> RAM (high byte)                **
;**   ignore spaces, comma or \n terminated                  **
;**   target RAM must be large enough to hold expected value **
hex2bin
;process high byte first
    movf    postinc0,w        ;get next character
    sublw    '\n'            ;is it a newline?
    retz                ;yes, we are done
    addlw    22            ;is it a space?
    bz    hex2bin            ;yes, ignore it
    addlw    12            ;is it a comma?
    sublw    -14            ;'A'-'F' = 7-12, '0'-'9' = -10 - -1
    skpc                ;correct for 0-9
    addlw    7            ;'0'-'9' = -3 - 6
    addlw    3            ;final result
    swapf    wreg,f            ;swap for high nibble
    movwf    indf1            ;and save
;then low byte (no need to check for terminators on odd characters)
h2b1    movlw    58
    subwf    postinc0,w        ;'A'-'F' = 7 - 12, '0'-'9' = -10 - -1
    iorwf    postdec1,f        ;merge in low nibble
    bra    hex2bin            ;do for all characters
joeyd999
Joined Jun 6, 2011
5,283
Oh, and regarding HEX2BIN...if anyone's got a better way to convert a string of an arbitrary number of arbitrary length hex values (in ascii) to binary, I'd love to hear it. Mine's fast, but I don't like the way it looks.
joeyd999
Joined Jun 6, 2011
5,283
Re private characteristics and nRf:
It seems that the problem is not with nRF. I've found other bluetooth scanner apps, and they all hang when trying to connect when I have the private characteristics defined.
The RN4020 is telling me the private characteristics are setup properly.
So, there is either a problem with my phone, or with the RN4020. Unfortunately, I didn't bring my tablet today to try a different device. Anyone got a phone I can borrow?
Edit: if anyone here has worked with bluetooth LE, and, specifically with private characteristics, can you help?
GopherT
Joined Nov 23, 2012
8,009
Not to shoo you way from here but the Bluetooth sub-forum over at microchip.com seems to be a hotbed of RN4020 questions and a few excellent people with answers.
http://www.microchip.com/forums/f505.aspx
joeyd999
Joined Jun 6, 2011
5,283
Fixed! The problem was the UUID for the private service. The RN4020 seems to choke on all the zeros.
Random numbers work much better.
joeyd999
Joined Jun 6, 2011
5,283
BTW, this is one of the reasons why I love Microchip. I called my FAE at 11 am this morning, telling him of the problem. Within an hour or so, there was another Microchip Bluetooth engineer sitting with me in my office helping to solve the problem. Thanks, guys.
joeyd999
Joined Jun 6, 2011
5,283
Yay! Everything is working. I can turn the bluetooth module on and off, check the existing settings (including private characteristics and capturing their 'handle' from the LS command) are reload the settings if necessary, connect and disconnect, and detect and act on, and parse, non-standard responses.
All that is remaining is to handle notifications, indications, and actually writing data to my own private characteristics. That is all pretty easy as the foundation already supports it.
I've removed the requirement for initialization (BTINIT), so the routine is gone. The state machine is smart enough to initialize all by itself during the standard polling process in the main loop of the application code.
I spent much time on the 'LS' command. It produces a table of server services, including primary services and my own private services. The hard part was to parse the table with the minimum code possible while not requiring to duplicate string constants in program memory. It's all good now. I do not think I will require parsing of the 'LC' command -- if so, I can likely reuse the routines that process 'LS'.
This code is very nearly production ready. And the best part is, I wrote it as a module that I can include in any existing 18F project -- another notch in my library belt. Bluetooth in minutes!
Oh! Last thing: as far as I know, the text parsing is pretty complete and robust. This means I can use the responses to control the state machine without even looking at the hardware signals. I can free up two port pins on my CPU, so I only require 4 connections to the RN4020 instead of six. This is pretty cool, IMHO.
Here are the definitions for the module:
Code:
;important Bluetooth states
cbtsid    equ    0        ;idle until bluetooth on and awake
cbtssu    equ    1        ;begin setup -- get feature string
cbtsls    equ    6        ;send LS command
cbtsrbt    equ    10        ;reboot
cbtsaps    equ    11        ;add private services
cbtsadv    equ    14        ;start advertising
;Bluetooh constants
cnumcar    equ    5        ;number of private characteristics
;Bluetooth Flags
#define    fbtrbt    btflag0,0,1        ;1=bluetooth requires reboot
#define fbtcaph    btflag0,1,1        ;1=capture characteristic handle during parsing of UUIDs in LS
#define FSRNFL    btsresp+1,0,1        ;"NFail"
#define FSRCMD    btsresp+1,1,1        ;"CMD"
#define FSREND    btsresp+1,2,1        ;"END"
#define    FSRNSR    btsresp+1,3,1        ;non-standard response received
#define    FWRNFL    btswait+1,0,1        ;"NFail"
#define    FWRCMD    btswait+1,1,1        ;"CMD"
#define FWREND    btswait+1,2,1        ;"END"
#define    FWRNSR    btswait+1,3,1        ;non-standard response received
#define    FWRNSRX btswait+1,7,1        ;non-standard response not processed
;macros
txpstr    macro    paddr            ;send string from program memory
    movlf    tblptrl,low paddr
    movlf    tblptrh,high paddr
    call    _txpstr
    endm
rxpcstr    macro    paddr            ;compare received string with paddr
    call    _rxpcstr
    endm
The strings used by the module:
Code:
;** Strings **
sbtgfs    db    "GR\r\0"            ;get features
sbtsfs    db    "SR,00060000\r\0"        ;no auto-advertise, no authentication
sbtgfn    db    "GN\r\0"            ;get friendly name
sbtsfn    db    "S-,WECoyote2\r\0"        ;set friendly name
sbtgmod    db    "GDM\r\0"
sbtsmod    db    "SDM,AAC1000\r\0"        ;set model
sbtgmn    db    "GDN\r\0"
sbtsmn    db    "SDN,Acme Products\r\0"        ;set manufacturer name
sbtgbms    db    "GS\r\0"
sbtsbms db    "SS,40000001\r\0"        ;allow private services
sbtls    db    "LS\r\0"            ;list services
sbtsps    db    "PS,4FB69667EB9C473992E26908642B1CD0\r\0"    ;set private service UUID
sbtsc1    db    "PC,4CD584F575A14A36833C83D0E75BA483,02,14\r\0"    ;add private service characteristic UUID
sbtsc2  db    "PC,4B90C8B122644767AC0FF10630185C19,02,14\r\0"
sbtsc3  db    "PC,2402A03123EE4E2B919BCF128281B6D5,02,14\r\0"
sbtsc4  db    "PC,4202E4BECC194B2F895234F4AF83609A,02,14\r\0"
sbtsc5  db    "PC,7828D3A795EC48BB961C87B0214CA594,02,14\r\0"
sbtres    db    "R,1\r\0"                    ;reset
sbtkill    db    "K\r\0"                        ;kill current connection
sbtdorm    db    "O\r\0"                        ;dormant
btsmes    db    "AOK\nERR\nBonded\nSecured\nConnection End\nReboot\n\x00CMD\nConnected\nNFail\nCMD\nEND\n\r"
btnsmes    db    "ConnParam:\nNotify,\nIndicate,\nWV,\nWC,\nRV,\n",0
And the actual code:
Code:
;** BLTOG -- Toggle Bluetooth on/off **
bltog    bbs    fbton,bltoff        ;turn bluetooth off?
;Turn bluetooth off
blton    bsf    fbton
    return
;Turn bluetooth on
bltoff    bcf    fbton
    return
pollbt    retbc    run            ;don't process bluetooth until system initialized and running
    clrf    btsresp+1,1
    iorwf    btswait+1,w,1
    andwf    btsresp+1,w,1
    bnz    pbstate
    iorwf    btswait+1,w,1
    iorwf    btswait+1,w,1
pbterr    movlb    0
pbtrto    movlb    0
    clrf    btswait+1,1
    movfw    btstate
    call    cjump
;idle with bluetooth off
    bra    btsid0            ;state 0:  idle awaiting BTAWAKE hardware line if bluetooth on
;setup blue tooth
    bra    btssu0            ;state 1:  begin setup, get feature string
    bra    btssu1            ;state 2:  get/set friendly name
    bra    btssu2            ;state 3:  get/set model name
    bra    btssu3            ;state 4:  get/set manufacturers name
    bra    btssu4            ;state 5:  get/set bitmap services
    bra    btssu5            ;state 6:  send LS to confirm private services
    bra    btssu6            ;state 7:  confirm private service UUID is defined
    bra    btssu7            ;state 8:  confirm all private characteristic UUIDs
    bra    btssu8            ;state 9:  scan for end of LS list
    bra    btssu9            ;state 10: start reset/reboot process -- clear private services
    bra    btssuA            ;state 11: add private services
    bra    btssuB            ;state 12: iteratively add private characteristics then reboot
    bra    btssuC            ;state 13: wait for reboot to complete and redo LS to load handles
;idle with bluetooth on
    bra    btsadv            ;state 14:  start advertising
    bra    btsid1            ;state 15:  idle for connects/disconnects and monitor monitor for shutdown
;shudown bluetooth
    bra    btssd0            ;state 16:  put bluetooth in idle mode
    bra    btssd1            ;state 17:  clear wakesw
    bra    btssd2            ;state 18:  clear wakehw
;-- State 0:  wake BT, await BTAWAKE hardware line, then wait for CMD message
btsid0    bbc    fbton,ibtex            ;do nothing if bluetooth not activated
    bsf    wakesw                ;ensure bluetooth is awake
    bsf    wakehw
    bcf    fbtrbt                ;clear reboot flag for setup
    bsf    fwrcmd                ;wait for "CMD"
    bra    ibtext                ;with 200ms timeout
;-- State 1:  begin setup, get, compare, and set feature string if necessary
btssu0    bbs    fsrnsr,btssu01            ;gf data received (as non-standard response?)
btssu00    txpstr    sbtgfs                ;get feature settings string
    bsf    fwrnsr                ;  wait for non-standard response
    bra    ibtex                ;  wait 200ms and don't advance
btssu01    rxpcstr    sbtsfs                ;expected value received?
    skpnz
    bra    ibtns                ;yes, advance to next state
    bsf    fbtrbt                ;indicate a reboot is going to be required
    txpstr    sbtsfs                ;send feature settings string
    bra    ibtexat                ;and advance
;-- State 2:  get, compare, and set friendly name if necessary
btssu1    bbs    fsrnsr,btssu10            ;friendly name received (as non-standard response?)
    txpstr    sbtgfn                ;get friendly name string
btssu10    rxpcstr    sbtsfn                ;expected value received?
    skpnz
    txpstr    sbtsfn                ;send new friendly name
;-- State 3:  get, compare, and set model if necessary
btssu2    bbs    fsrnsr,btssu20            ;model received (as non-standard response?)
    txpstr    sbtgmod                ;get friendly name string
btssu20    rxpcstr    sbtsmod                ;expected value received?
    skpnz
    txpstr    sbtsmod                ;send new friendly name
;-- State 4:  get, compare, and set msnufacturer's name if necessary
btssu3    bbs    fsrnsr,btssu30            ;manufacturer's name received (as non-standard response?)
    txpstr    sbtgmn                ;get manufacturer's name string
btssu30    rxpcstr    sbtsmn                ;expected value received?
    skpnz
    txpstr    sbtsmn                ;send new manufacturer's name
;-- State 5:  get, compare, and set bitmap services if necessary
btssu4    bbs    fsrnsr,btssu40            ;bitmap services received (as non-standard response?)
    txpstr    sbtgbms                ;get bitmap services string
btssu40    rxpcstr    sbtsbms                ;expected value received?
    skpnz
    txpstr    sbtsbms                ;send new bitmap services
;-- State 6:  send LS command to confirm private characteristics set up properly
btssu5    clrf    bthctr,1            ;clear handle counter for later
    txpstr    sbtls                ;send ls
    bsf    fwrnsr                ;wait for non-standard response
    bsf    fwrend                ;allow an END if nothing in the list
    bra    ibtext                ;and await response
;-- State 7:  check if the private service is defined
btssu6    bbs    fsrend,btrbt            ;if END received, list is empty, reset and reboot
    rxpcstr    sbtsps                ;expected value received?
    bz    btssu60                ;yes, set up for private characteristics
    bra    ibtex                ;await response and return here
btssu60    bsf    fwrnsr                ;wait for non-standard response
;-- State 8: iterate to check UUID for each private characteristic -- capture handle if exists
btssu7    bbs    fsrend,btssu70            ;if END received, ensure we got all characteristics
    movfwb    bthctr                ;have we exhausted the number of characteristics?
    xorlw    cnumcar                ;compare
    bz    btssu71                ;yes. Should have been END. Scan to END, reset and reboot.
    movlf    tblptrl,low sbtsc1        ;tblptr->first characteristic setup string
    movlf    tblptrh,high sbtsc1
    movlw    44                ;43 bytes per private service string
    mulwf    bthctr,1            ;prod = index into list of strings
    movfw    prodl                ;set tblptr->correct characteristic string
    addwf    tblptrl,f
    clrw
    addwfc    tblptrh,f
    bsf    fbtcaph                ;indicate we want private characteristic handle captured
    call    _rxpcstr            ;compare string & capture handle
    bnz    btssu71                ;no, string not matched.  Scan to end, reboot and reset
    incf    bthctr,f,1            ;bump counter for next private characteristic
    bra    ibtex                ;come back to this state with response
;  END received -- ensure we captured [cnumcar] characteristics
btssu70    movfwb    bthctr                ;have we exhausted the number of characteristics?
    bnz    btrbt                ;no. Should have been END.  Reset and reboot.
    movlfb    btstate,cbtsrbt            ;all good, but reboot if necessary
    bra    ibtex
;  No match.  Scan to END, reboot and reset
btssu71    bsf    fwrnsr                ;wait for non-standard response
    bsf    fwrend                ;wait for END if nothing in the list
;-- State 9: scan for END, reboot and reset
btssu8    bbs    fsrend,btrbt            ;reset and reboot if END received
    bsf    fwrnsr                ;otherwise, wait for non-standard response
;-- State 10: start reset/reboot process if necessary -- clear all private services
btssu9    bbs    fbtrbt,btssu90            ;reboot necessary?
    movlfb    btstate,cbtsadv            ;no, start advertising
    bra    ibtex
btrbt    movlfb    btstate,cbtsrbt            ;jump in here. Set to this state.
btssu90    bcf    fbtrbt                ;clear reboot flag for next pass
    txpstr    sbtcps                ;clear any existing private services/characteristics
;-- State 11: add private services
btssuA    clrf    bthctr,1            ;preclear handle counter to index private characteristics
    txpstr    sbtsps                ;add private servcie
;-- State 12: iteratively add private characteristics, then, reboot
btssuB    movfwb    bthctr                ;have we exhausted the number of characteristics?
    bz    btssuB0                ;do actual reboot
                        ;including stupid assembler padding 0
    addwf    tblptrl,f
    clrw
    addwfc    tblptrh,f
    incf    bthctr,f,1            ;index to next characteristic
    call    _txpstr                ;transmit string
    bra    ibtex                ;and return to this state
;all characteristics set.  Reboot
btssuB0    txpstr    sbtres                ;send reset
    bra    ibtext
;-- State 13: wait up to 3,200 ms for reboot sequence -- then go do LS all over again to load handles
btssuC    bsf    fwrzcmd                ;wait for '\0CMD'
    movlfb    btstate,cbtsls            ;set up LS as next state
    bra    ibtex
;-- State 14: start advertisement
btsadv    txpstr    sbtadv                ;send start advertisement
;-- State 15: idle as connected/disconnect -- monitor fbton in case bluetooth is to shut down
btsid1    bbc    fbton,btsid11            ;bluetooth needs to turn off?
    bbs    FSRCEND,btsid10            ;disconnect received?
    bsf    FWRCON                ;allow connection response
    bsf    FWRCEND                ;allow connection end response
    bsf    FWRNSR                ;allow non-standard for notifications
    bra    ibtex                ;and come right back next pass
;disconnect received -- start advertising again for seamless reconnect
btsid10    txpstr    sbtadv                ;send start advertisement
    bsf    FWRAOK                ;allow ok
    bsf    FWRERR                ;or error
;shut down gracefully -- kill any existing connections
btsid11    txpstr    sbtkill                ;send kill command
    bra    ibtexae                ;allow ERR if not connected
;-- State 16:  put bluetooth into dormant mode
btssd0    txpstr    sbtdorm                ;send dormant command
    bra    ibtexat                ;wait for aok
;-- State 17: shutdown bluetooth
btssd1    bcf    wakesw                ;turn off bluetooth uart transmitter
    bsf    FWREND                ;end message will be response
    bra    ibtext                ;
;-- State 18: complete shutdown -- pull wakehw low
btssd2    bcf    wakehw                ;pull line low
    movlfb    btstate,cbtsid            ;set up idle0 as next state
    bra    ibtex                ;no messages expected
;****** END OF STATE MACHINE STATES ******
;set up next state
ibtex    movlb    0
    return
btprcv    movlf    fsr1h,high btrcvbuff    ;point to receiver buffer
    retz                ; z if none
    cpfseq    indf1
    xorwf    tablat,w
    rlcf    btsresp,f,1
    rlcf    btsresp+1,f,1
    xorwf    tablat,w
btpmat
    return
    xorwf    tablat,w
btpnnf    bsf    fwrnsrx            ;indicate non-standard response not processed
    bra    btnsnfy            ;'Notify,'
    bra    btnsind            ;'Indicate,'
    bra    btnswv            ;'WV,'
    bra    btnswc            ;'WC,'
    bra    btnsrv            ;'RV,'
    return
;other non-standard responses -- for later -- just indicate unhandled for now
;notification received
btnsnfy                    ;'Notify,'
;indication received
;write value to local server characteristic
btnswv                    ;'WV,'
;write configuration to local server characteristic
btnswc                    ;'WC,'
;real time read (bit must be set in supported features (SR)
btnsrv                    ;'RV,'
    bra    btpnnf            ;indicate unhandled non-standard response
hex2bin
    swapf    wreg,f            ;swap for high byte
h2b1    movlw    58
;** RXPCSTR -- Compare received string with program memory     **
;**   program memory string terminated with \r                 **
;**   tblptr -> string                                         **
;**   ignore leading characters in PM until first comma        **
;**   ignore leading spaces in RAM                             **
;**   z if match, nz if no match                               **
;**   if fbtcaph is set, handle for char #(bthctr) is captured **
_rxpcstr
    lfsr    0,btrcvbuff        ;point to bluetooth receive buffer
    movlw    ','            ;skip to character after first comma
rxpclp0    tblrd    *+
    cpfseq    tablat
    bra    rxpclp0
rxpclp1    movlw    ' '            ;ignore leading spaces in RAM
    xorwf    postinc0,w
    bz    rxpclp1
    movf    postdec0,w        ;move pointer back to first non-space character
rxpclp2    tblrd    *+            ;get character from program memory
    movlw    '\r'            ;terminates with /r
    xorwf    tablat,w        ;compare
    retz                ;return with z to indicate match
    bbc    fbtcaph,rxpcb0        ;capture handle flag set?
    movlw    ','            ;handle starts at first comma
    xorwf    indf0,w            ;compare
    skpnz
    rcall    rxpch            ;go capture handle
rxpcb0    movf    indf0,w
    movfw    tablat            ;get pm character
    xorwf    postinc0,w        ;compare with received character
    bz    rxpclp2            ;match, keep going
    return                ;return with no match
;capture handle at current ram position +1
rxpch    bcf    fbtcaph            ;clear capture flag for any remaining commas
    lfsr    1,hpchar1        ;fsr1->start of characteristic handle table
    rlncf    bthctr,w,1        ; *4 (size of handle)
    rlncf    wreg,w
    addwf    fsr1l,f            ;fsr1->proper handle
    movff    preinc0,postinc1    ;copy 4 bytes
    movf    postinc0,f        ;index to tailing comma
    return                ;and go finish scan
    include    "btstrings.asm"        ;include command/response strings
joeyd999
Joined Jun 6, 2011
5,283
Oh! And here are the register definition specific to the Bluetooth code:
Code:
#ifdef BLUETOOTH
;Bank 4 RAM (0x400-0x4ff 256 available) ;Bluetooth configuration only
    cblock    0x400
;bluetooth processing registers
    btflag0                ;bluetooth flags
    btsresp:2            ;standard response flags
    btswait:2            ;wait for a particular response
                    ;bit 0 -- AOK
                    ;bit 1 -- ERR
                    ;bit 2 -- BONDED
                    ;bit 3 -- SECURED
                    ;bit 4 -- CONNECTION END
                    ;bit 5 -- REBOOT
                    ;bit 6 -- \0CMD
                    ;bit 7 -- CONNECTED
                    ;bit 8 -- NFail
                    ;bit 9 -- END
                    ;bit 10-- non-standard response
                    ;bit 11--
                    ;bit 12--
                    ;bit 13--
                    ;bit 14--
                    ;bit 15--
    btstime                ;bluetooth state machine timer
    btstate                ;bluetooth state machine counter
    btrhead                ;bluetooth receiver head pointer
;non-standard response received values
; -- from ConnParam:
    supto:2                ;supervision timeout
    slatency:2            ;slave latency
    conint:2            ;connection interval
; -- private characteristic handles from LS command
    bthctr                ;handle counter for parsing
    hpchar1:4
    hpchar2:4
    hpchar3:4
    hpchar4:4
    hpchar5:4
    endc
;Bank 5 RAM (0x500-0x5ff 256 available) ;Bluetooth configuration only
    cblock    0x500
    txbuff:256                ;EUSART transmit buffer (256 bytes)
    endc
;Bank 6 RAM (0x600-0x6ff 256 available) ;Bluetooth configuration only
    cblock    0x600
    rxbuff:256                ;EUSART receive buffer (256 bytes)
    endc
;Bank 7 RAM (0x700-0x7ff 256 available) ;Bluetooth configuration only
    cblock    0x700
    btrcvbuff:256                ;BT receiver buffer
    endc
#endif
joeyd999
Joined Jun 6, 2011
5,283
The very last thing I'll probably do, after *all* the code is finished, is to add a supervisor that performs a hard hardware reset in the case of timeout errors. I haven't had any, but if I did, the current code would try to limp on, probably unsuccessfully.
