microC software i2c with pic16f877
sumani
Joined Mar 12, 2009
8
hi,
unfortunately i can not understand MicroC software I2C example.
if it's possible, learn me how can i use defined function (Software I²C Library) for PIC16F877A and 24lc64, please.
i want one sample code for learning that functions.
or
could anyone please explain me how write the word 'computer' into the 24lc64 i2c eeprom which is connected with pic16f877a at PORTB {Soft_I2C_Config(&PORTB, 1, 2);} and read it back.
thatoneguy
Joined Feb 19, 2009
6,359
Seems you made a Double Post.
MikroC has an I2C example I2C program under examples/BigPic5/18Fxxxx/RTC.C
The realtime clock on their boards is through I2C, so any of the clock code examples will give you the I2C code in Mikro C. Mine is heavily commented, both read and write.
Which example were you viewing?
sumani
Joined Mar 12, 2009
8
hi sorry for that inconvenience.
I've gone through both examples. but i couldn't understand both.
this is the part of the coding i extract from the write example..
Soft_I2C_Write(0xA0); // address PCF8583
Soft_I2C_Write(0); // start from word at address 0 (configuration word)
Soft_I2C_Write(0x80); // write $80 to config. (pause counter...)
Soft_I2C_Write(0); // write 0 to cents word
Soft_I2C_Write(0); // write 0 to seconds word
Soft_I2C_Write(0x30); // write $30 to minutes word
Soft_I2C_Write(0x11); // write $11 to hours word
Soft_I2C_Write(0x30); // write $30 to year/date word
Soft_I2C_Write(0x08); // write $08 to weekday/month
in above coding what is 0xA0, configuration word, 0x80?
and could you please explain what is actually happening when run above coding?
how can i modify this code to write a word (lets say that word is 'computer')into the eeprom (24lc64)?
thatoneguy
Joined Feb 19, 2009
6,359
My examples look like this:
Rich (BB code):
I2C_Init(100000);         // initialize I2C communication
  I2C_Start();              // issue I2C start signal
  I2C_Wr(0xA2);             // send byte via I2C  (device address + W)
  I2C_Wr(2);                // send byte (address of EEPROM location)
  I2C_Wr(0xF0);             // send data (data to be written)
  I2C_Stop();               // issue I2C stop signal
To send a string of data, it needs to be sent one character at a time, since it is a serial protocol.
The initial write is for addressing which device on the bus will be "spoken to"
See I2C Introduction
sumani
Joined Mar 12, 2009
8
hi
thank you for your reply. The recommended link is very helpful. now i can go ahead on my project.
thanks a lot.
