Micro USB pinout on schematic - Help!
Discussion in 'General Electronics Chat' started by dmc0162, Feb 11, 2015.
  1. dmc0162
    Thread Starter Active Member
    Dec 13, 2007
    51
    I am looking at a schematic for an IC that outputs to a micro USB connector. I am familiar with USB pins obviously having Vcc, Gnd, D+, D-, and an ID pin which can be grounded to distinguish host/slave device on micro connectors. However, I am not sure how to interpret this wire connection coming from the SIDE of the OUTPUT USB connector in this data sheet schematic. I don't think it is the ID pin because it does not run to GND. Does anybody have any idea what they mean by that side connection?
    Thanks!
    integrated circuit likes this.
  2. ericgibbs
    Jan 29, 2010
    2,588
    389
    hi,
    When S1 is set Closed,[for 100mSec] the ID pin #5, is connected to 0V via R13, also the ACT is enabled.
    E
  3. dmc0162
    Dec 13, 2007
    51
    Thank you!!
  4. dmc0162
    Dec 13, 2007
    51
    Edit.
  5. Dan Micu
    Jun 12, 2015
    20
    Really interesting since I'm having the same dilemma .. A Micro USB type B has 5 pins and there are many conflicting answers on the web .. What pisses me off is that neither Molex or Hiroshi map the pins in their specs .. so annoying trying to guess what is what .. I used my voltmeter to try and measure, but the plug is so tiny I find the Vcc pin .. I'm guessing pin 1 is Vcc and Pin 5 is ground ..
