MICRO SWITCHES wiring diagram
Discussion in 'General Electronics Chat' started by cessnadriver, Feb 17, 2013.
Thread Status:
Not open for further replies.
  1. cessnadriver
    Feb 17, 2013
    5
    Hello ALL.
    I am new to your forum! I hope I'm in the correct department?
    Here goes. Attached is a schematic for "Cowl Flaps" on an airplane. If you look at the CIRCLED DPDT(?) switches, I'd like to change this to two Micro switches (as ON-ON )?? As you go through the diagram from the CIRCLED DPDT switches you'll see two micro switches (these are limit or stop switches). View attachment Cowl flap circuit c3370001.pdf
    That said does anyone/everyone think it can be done?? Also I'm fairly smart with electrical wiring, but I have to admit these three terminal micro switches have me a bit stumped!!
    Thanks for looking!
    Sincerely,
    BILLS
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    The Completed Projects Forum is for Completed Projects only. It is meant to allow members to show plans for projects they built so other members can duplicate them if desired. New threads are also automatically moderated per Moderator review for this reason. Your thread does not belong in this forum, and was moved here.
    cessnadriver likes this.
  3. BillB3857
    Feb 28, 2009
    2,402
    348
    The three terminals on a micro-switch should be marked as C, NC and NO. If they are not marked, it is easy to figure out using a meter. If you don't know how to do that, I wouldn't want to fly in the airplane you are working on. I know it sounds harsh, but it sure sounds like a major safety issue to modify cowl flaps on an airplane.
  4. ErnieM
    Apr 24, 2011
    7,442
    1,628
    I just cannot answer this post. Too much can go wrong with this.
    We don't let automotive mods on here. This can kill many more people.
    cessnadriver and thatoneguy like this.
  5. Georacer
    Nov 25, 2009
    5,151
    1,266
    Indeed. The terms of service don't explicitly restrict aircraft topics, but common logic dictates that any concern for automotive dangers is tenfold for aircraft.
    Please consult a verified technician.
Thread Status:
