OK, the circuit board layout is correct, and you got the reading you should have from the relay; continuity between 1-5-8 with no power applied to either coil.
I drew the relay with the contact showing 4-8 made instead of 5-8 made; which threw me off.
I have corrected the art for the library model; the top part layout is attached.
Once you get the board etched and drilled, you could glue the layout to the top of the board.
Just in case the board copper is a bit thin around the edges, you might add this jumper:
It's to make sure ground is well connected to both sides of the circuit. Right now, the "copper pour" has everything connected, but if you're a bit thin around the edge of the board where the transistor is, you might have a problem.
This just avoids any potential problem.
Better use an insulated jumper wire, as the trace the jumper needs to cross over is connected to MOT-; the trace will be grounded while the motor is running in the forward direction (T.C. starting his turn), but Vcc (+7.2v) when the motor is running in reverse (T.C. returning to forward).
Got it etched drilled populated and wired up including the jumper. Motor will start ad go around but the reed switches have no effect at all. I can hear them open and shut as the magent passes byt it does not reverse or stop.
It Works!!! I mean it really honest to gosh works! Found the minor problem. It really helps if you solder the switch lead in...oops!! Okay now to get the figure painted, mounted and adjusted. Then into TIGER tank 312!!
Oh Boy...Oh Boy...Oh Boy!!
I'll post a video as soon as I get it all in one sock!
Oh, you're talking about R2, the 220 Ohm resistor that limits motor current?
You could try various values. 270, 330 Ohms, 390 Ohms, 470 Ohms... if you go past around 620 Ohms, it'll probably start getting mighty jerky.
If you're going to do another one of these things, might look at doing the whole deal in a transistorized H-bridge, and add on a PWM circuit so that you can "tweak" the motor speed to your heart's content.
Sorry for the delay. Puter took a big nose dive. I was already to go. It was assembled tested and I was getting ready to make the video, and thought better test it one more time. What I failed to see was my pliers across the board. So when I powered it up...well you can guess. My tank commanders head went around before flying off somewhere behind my bookcase.
But I have rebuilt a new board. My TC should be out of the hospital soon. I gave him a head transplant. So soon I will be able to show the world the incredible 1/16 scale moving Tiger Tank Commander.
I sure did and the 330 is the way to go! Right ow I'm making a case for the new board so I won't goof it up again. You are right! Making these boards is fun.
Actually, you could use some insulating tape on the bottom of the board to protect it.
DON'T use "Electrician's Tape" - the glue will soften and fall off after a few months.
Making a case is OK if you can keep stuff from getting inside the case. If some piece of metal gets in there and rattles around, it will wind up shorting out the traces and cause problems. Using RTV silicone at wiring entrance/exit points will help prevent that from happening.
If you are satisfied that it's working properly and don't want to see it again, you could always use potting compound to permanently protect it. The relay isn't going to die with the small load you have; it's rated for 30A. The weakest points are the traces on the board.
All is looking good, real good! Waiting on a new hand and binoculars, Then the headphones and throat mike. I received some very nice uniform decals that will make this guy really a show piece.
I was looking at the ELCTROINCIS GOLDMINE and found they have car remotes and recievers. For those that do not have the RX-18 or the ELMod would it be possible to have the board, reciever operated by a 9 volt battery? That way anyone no matter what tank could use it.
If you get much lower than that, the relay won't engage. If you go much higher, there will be too much current through the relay coil.
9v "transistor" batteries won't last very long. They would be better off using eight AA cells in a battery holder; the board will be very happy running with that.
Thanks Sarge! I just read the spec sheet and the car remote would be a living breathing nightmare. However the ultrasonic TX and RX look promising. It operates on 24Mhz and the tanks operate on 27Mhz. Hopefully not to close. I would hate to push the button and a $1500 dollar tank rolls off a cliff.
Connect up the +/-12v to the battery via a fuse. Connect the NO input to the +12v input so it's fused, too. Connect COM to the RX-18 input on the TC driver board.
Alternatively, COM could be connected to the fused +12v input and NO connected to the RX-18 input on the TC driver board but that would leave the NC terminal energized all of the time.
