OK, it took a good bit of fiddling around but I discovered that I had a couple of errors in a library. Hope you didn't waste any of that press & peel stuff; it isn't cheap.
The new board (Rev1) looks about the same; but I had to move a few things around. It's now exactly 1-3/4" square. I didn't bother to put mounting holes on there; I figured you'll drill a couple of holes or maybe just use some velcro on the back in case you want to pull it out easily.
You'd said before that the RX-18 outputs 7.2v, so I didn't put in a + connection for your RX-18.
[eta] Found another error - arrrgh! fixed, re-uploaded all files
Sarge one of the items in that post got me to thinking,
(thats dangerous.)
The 1/16 scale tanks I build use 7.2 volt motors (2) Is there a Circuit that could read the voltage going to the motors, and match that to a sound module. End result being that when the tank is sitting still all you hear is the engine idle. When the tank moves forward the sound of the engine and track nosies increases with speed. I have sounds of a KING TIGER and a Panther. For the KING TIGER I have not only the engine sounds but the two methods of startigthe Engine, electric and crank. Just an idea.
Let's get this project wrapped up and working, otherwise we'll get way sidetracked. I just thought you'd get a kick out of it. I have a feeling that a big tank might be in your future, down the road a piece
As far as the sound goes; something like Roman Black's BTc PIC implementation might be pressed into service: http://www.romanblack.com/
it would require looping a short sample at various rates, depending on an ADC input. I just stumbled across that application & hardware yesterday, but I don't see offhand why it couldn't be adapted to your needs. Since the tank's sounds will be low frequency anyway, that'll be relatively easy to reproduce.
Oh I know, that project will be in the future. However I find if I don't write it down somewhere I get lost. And speaking of big tanks. Here is the dream. 1/4 Scale Tiger 1. These use 12 Ga. Blanks, can tow small cars, and weigh in at about 300 lb or more. Cost? Oh with everything about $11,000 not including shipping from the UK.
Don't do that, You get me exited about something else and I will get sidetracked. Sound, WOW. If you guys get on that subject, be sure and get me in the loop.
I'm gonna nominate you for the first Homer Simpson award for the new year!
dOH!
Actually, I beat you to the big dummy thing... when I was laying out the board, the transistor orientation didn't look right (emitter base collector); the emitter and collector were swapped, so I went into the Eagle transistor.lbr library to figure out what was going on... and then I "realized" that the package layouts for all the TO92 packages had their leads swapped around, so I swapped them how they were "supposed" to be; and then I went to look at the device connections to the symbols, and realized that THOSE were all backwards too.... then I realized that I goofed up with my first realization and had to swap them all back over again.... it was like a Chinese fire drill.
I've never used it. However, it would probably be a good idea.
You could always just spray clear lacquer over the bottom of the board to seal it, after you're done with all of the soldering and cleaned it off really well. Lacquer thinner will get it right off if you need to fix/change things later.
Are you going to try Rev2? I'd like to know if it's going to work.
Well Sarge the Fire Ball was not too big. Don't know what went wrong. Used the multi-meter to make sure all the traces were good. Board was etched perfectly. I used my opti-visor to inspect the traces after soldering.
You should see how reed switches look when they glow. Hummmm I think I'll etch another board and get some more bits and try again. Can you think of anything?
Ouch!
You made the Rev1 board, right? Which switch got toasted?
If D1 or D4 were backwards or shorted, that could easily toast S2.
If D3 were backwards or shorted, it could toast your RX-18 output.
You might want to put small fuses in those lines (say, 1A) just in case those diodes fail shorted.
I didn't like that layout much; that's why I went to the Rev2 board. Please don't try making another Rev1 board. I don't know why your reed switch got fried, but I'm going to double-check the Rev2 board to see if there is a problem.
But before you make a Rev2 board, let me go over it with a fine-tooth comb.
