Micro pump design
sagi4422
Joined Aug 29, 2009
34
I am working on some experiment to create/analyze a micro pump to deliver fluid
I would like the fluid to deliver from a tank to the outer which is for the example, water.
I need this pump to be in the micron size and low-power consumption
Can you please advice for :
a purchasing product (if there is)
a circuit I can go over and see how to change the frequency, voltage etc...
More than that, I would like to know which materials I need to create this circuit.
Thanks in advance,
Sagi
bertus
Joined Apr 5, 2008
22,278
What are the requirements?
What range should the flow be?
I think you will end up with some laboratory equipment.
Greetings,
Bertus
bertus
Joined Apr 5, 2008
22,278
What kind of liquids do you want to pump?
What amount of liquid is to be pumped?
Is it nl/min or μl/min or ml/min or l/min.
Greetings,
Bertus
sagi4422
Joined Aug 29, 2009
34
I need to pump oxybutynin dissolved in water.
The amount is 2mg per 24 hours in frequency of 1/min means 1.4e-3mg per minute.
Thanks,
Sagi
bertus
Joined Apr 5, 2008
22,278
You say the substance is dissolved in water.
How many of the substance is there in a liter of water?
How many of the liquid should be pumped?
Greetings,
Bertus
sagi4422
Joined Aug 29, 2009
34
In a liter of water there is 1000mg of substrate (solubility 1mg/ml)
The total pump should be 360ml in 6months (1 pump per minute with 1.4e-3ml per minute, 2ml a day)
Thanks,
Sagi
sagi4422
Joined Aug 29, 2009
34
Thanks for the application you propose, there is any circuit that build with the piezoelectric actuator with equation I can look at and add my variables ?
Thanks,
Sagi
