Micro project box?
Discussion in 'The Projects Forum' started by danforth, Jun 1, 2011.
  1. danforth
    May 8, 2011
    22
    Where can I find a plastic box that is approximately 1.5"L x 1"W x 3/8"H?
    To fit a tiny pcb inside.
  2. someonesdad
    Jul 7, 2009
    1,585
    141
    Look at the usual suppliers like All Electronics, Goldmine, MP Jones, Radio Shack, etc.
    Note you can also make your own boxes from flat plastic stock. Get some acrylic or PVC and glue it together. PVC glue can be gotten at home centers and methylene chloride is the glue for acrylic. If you make nice smooth edges, acrylic can be glued quite successfully.
  3. Markd77
    Sep 7, 2009
    2,803
    594
  4. #12
    Nov 30, 2010
    16,663
    7,307
    I got some tiny plastic boxes very much like the one you described at Mouser. They look so much better than any home-made thing I could make out of flat pieces!
  5. russpatterson
    Member
    Feb 1, 2010
    351
    16
    Check out Hammond Enclosures website, then find a distributor, like digiKey, Allied, etc.
  6. KMoffett
    Dec 19, 2007
    2,584
    234
  7. jerseyguy1996
    Feb 2, 2008
    206
    9
    It may be a little bit too big for your project but the mini-altoids tins are probably close to the size that you are looking for. Just line the inside with electrical tape to prevent the metal from shorting out your circuit.
  8. KJ6EAD
    Apr 30, 2011
    1,426
    363
