Micro Processor
Discussion in 'General Electronics Chat' started by MURUGESAN K, Jan 27, 2014.
  1. MURUGESAN K
    Jul 16, 2013
    5
    Dear Sir,
    What are the components required for programming microprocessor 8085 by using PC?
  2. Ian Rogers
    Member
    Dec 12, 2012
    158
    29
    MURUGESAN K likes this.
  3. alfacliff
    Dec 13, 2013
    2,449
    428
    you would need memory, and all other stuff, the 8085 isnt a programable chip like a pic, its a microprocessor, like an 8080, or a 6800.
  4. takao21203
    Distinguished Member
    Apr 28, 2012
    3,578
    463
    GAL programmer + EPROM
    or you can use more expensive FLASH chips. Most flash is serial now but parallel FLASH chips do exist.
    when you don't know how to it is a lot of effort to make a 8085 circuit board.
  5. t06afre
    May 11, 2009
    5,939
    1,222
    A 8085 assembler tool and a 8085 software simulator.
  6. Ian Rogers
    Member
    Dec 12, 2012
    158
    29
    Its the same circuitry as used with the 8051 when using external parts..
      File size:
      150.4 KB
      18
  7. saraswathi.95
    Member
    Apr 11, 2013
    40
    some of the programming applications can be done using debug/tasm with dos .
  8. alfacliff
    Dec 13, 2013
    2,449
    428
    Ian Rogers, the same circutiry will ot work with 8051 and 8085, the 8085 has no built in i/o. the 8051 is an industrial controller, the 8085 is a genreal purpose micro processor. it was used in the trs80 model 100 portable computer. the language is quite similar, based on the roigional 8080 processor.
  9. Ian Rogers
    Member
    Dec 12, 2012
    158
    29
    Similar!!! I have built 8051 systems... and I have built 8085 systems
    You can use the 8051 in the same mode as the 8085 and map all your IO's in memory..
    I was also the proud owner of several Z80 based micro's...
    The very first XT's had a 8085 chip in.... I had one of them too...
  10. t06afre
    May 11, 2009
    5,939
    1,222
    No I am quite sure it used a 8086 CPU
  11. Ian Rogers
    Member
    Dec 12, 2012
    158
    29
    Yes!! They had the 8086 They also used the 8088!! on reflection it may have been the 8088 as that didn't go very far... I know they released an 80188 and a 80186 not long after...
    The 8085 became the MCS systems..
    The point I was making is that you can use the same circuitry as my example on the 8085...
  12. alfacliff
    Dec 13, 2013
    2,449
    428
    the same, excdept you have to decode all the addresses and data lines. you have to demultiplex the data to where it goes, unlike the 8051 whitch has pins for 8 bit i/o lines, the basic command bit structure is the same, both based on the 8080 commands, but with more commands added. used to work on video games, the early quarter types, with everything from all ttl to 68010 processors. now a lot of the industrial stuff I work on is (other than the main processor in cnc) based on the 8051 family.
  13. t06afre
    May 11, 2009
    5,939
    1,222
    In its time it was a lot of books about those 8 bit processors. I guess most of them are gone by now. I have this one in my bookshelf, the book is quite good
      File size:
      109.4 KB
      17
  14. Ian Rogers
    Member
    Dec 12, 2012
    158
    29
    You can run the 8051 as an 8085... The 8051 has an external address bus and is multiplexed with the data bus.. just like the 8085... I have two circuits and they look the same...
    Anyway!! The OP's not replied so this debate is pointless.
