micro processor
Discussion in 'Embedded Systems and Microcontrollers' started by bhuvana1490, Feb 17, 2009.
  1. bhuvana1490
    Feb 17, 2009
    This is my question
    How I can operate the micro processor, any body can help me.
  2. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
    You are not in the correct section:
    Feedback and Suggestions Forum for providing feedback and suggestions about All About Circuits, including corrections to the e-book and site. This forum is not for asking technical questions.
    Place it in the Embedded... section.
    Greetings,
    Bertus
  3. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    It is hard to answer your question. We do not know which microprocessor you are trying to operate, or how.
    Do you just have one in hand, and need to know how to program it? If so, obtain the data sheet for the device, along with the appropriate programmer package from the manufacturer.
  4. bhuvana1490
    Feb 17, 2009
    what are the instructions available under data transfer instruction in 8085 microprocessor.
  5. mik3
    Feb 4, 2008
    4,846
    63
    The instructions have to be listed in the microprocessors datasheet.
  6. bhuvana1490
    Feb 17, 2009
    what is a microcontroller
  7. triplehdineshbabu
    Feb 5, 2009
    38
    hi,
    Microcontroller is an IC like the Microprocessor additionally which consist of RAM, ROM, Interrupts, I/O ports, Timers and Counters.
  8. triplehdineshbabu
    Feb 5, 2009
    38
    Hi bhuvana,
    Data transfer instruction:
    Copy from source to destination
    MOV Rd, Rs
    M,Rs
    Rd,M
    This instruction copies the contents of the source register into the destination register; the contents of the source register are not altered. If one of the operands is a memory location, its location is specified by the contents of the HL registers.
    Example: MOV B, C or MOV B, M
    if you want to get more details about Microprocessor go to this link
    http://www.8085projects.info/forum/default.asp
