Micologic 1200 - PLC
Discussion in 'General Electronics Chat' started by superway, Sep 29, 2011.
  1. superway
    Thread Starter Active Member
    Oct 19, 2009
    128
    Can anyone help me this question?
    I have a PLC Micrologic 1200 (1762-OW16).
    I connect a 24vdc toVAC DC 0, VAC DC 1, VAC DC 2...
    The OUT 0, OUT 1, OUT2, OUT 3.... are connected to each LED (5mm)and series with each resistor. Can you please tell me what is the DC voltage from OUT 1, OUT2, OUT 3...? so that I can find the value of resistor and LEDs?
    CVN
  2. jwilk13
    Member
    Jun 15, 2011
    228
    12
    Maybe this will help. Or maybe you can power the unit on without any peripherals connected, set an output high, and use a meter to measure it.
    EDIT: My guess would be 24VDC though (at least for the FET digital outputs), if that's what you're wanting.
  3. GetDeviceInfo
    Jun 7, 2009
    1,571
    230
    seeing that the 1762-OW16 is a relay module, what you connect to common (VDC 0/VDC 1) is what you'll see on the out 1..16.
  4. jwilk13
    Member
    Jun 15, 2011
    228
    12
    Whoops, I skimmed over the 1762-OW16. I assumed the OP was talking about the built-in I/O.
    GetDeviceInfo is right. You'll find the details down the page here.
