I see....any tips on how to get rid of that?It may or may not have to do with your problem, but thicker = instability. There's a high-frequency component riding on your waveform.
The .0068uF again improved, but didn't totally fix the issue. I think I am at the point where the response is good enough, I can probably sleep at night if I leave it the way it is. Of course I would always be open to further comment or suggestion100pF to ground after that 47k resistor should do it! Or, since the source is probably the op amp gain stage, put .0068uF or so in parallel with the 200kohm feedback resistor.
It is regulatedHello,
Is the universal powersupply you are using a regulated one?
If not, put it to 15 Volts and use a 7812 to power the opamp and mic.
Bertus
Scope shows perfect 12.0VHello,
Can you measure the 12 Volts on the scope?
That way you can see if it is clean.
Bertus
Here is a pic at 5mvHello,
What do you see on the scope, when you set it to AC and scale the sensitivity to the mV range?
Bertus
Thread starter | Similar threads | Forum | Replies | Date |
Plug to PCB removal issues | Technical Repair | 3 | ||
Z | power issues | Power Electronics | 5 | |
S | AC adapter issues | Power Electronics | 6 | |
STM32F756VGH6 issues with establishing 2 timers at the same time | Microcontrollers | 11 | ||
Trying to figure out some preamp/amp compatibility issues | Analog & Mixed-Signal Design | 34 |
