mic and speaker system to help public school teachers
Discussion in 'The Projects Forum' started by octagonx, Nov 20, 2008.
  1. octagonx
    Nov 20, 2008
    6
    I want to build a portable device that will help public school teachers in teaching. The system i was thinking will incorporate a "lapel" or a small microphone and a loudspeaker that can be heard over a small classroom of about 40-50 people. The system must be battery operated and somewhat handheld (or can be worn on the waist).
    Since I'm new to audio, i don't know what speaker and speaker driver to be used. I saw one, the TDA2002 which is an 8W car speaker amplifier but i don't know if its going to be an overkill.
    Can anyone help me with what speaker and amplifiers to be used?
    Thanks a lot.
  2. KL7AJ
    Nov 4, 2008
    2,043
    292
    I think most teachers would be best helped by an old fashioned bullhorn. :)
  3. Audioguru
    Dec 20, 2007
    9,411
    896
    If the microphone can hear the speaker (it will if they are close together) then there will be acoustical feedback howling.
  4. octagonx
    Nov 20, 2008
    6
    microphone can hear speaker all the time. anyways, that doesn't answer my question...
  5. Wendy
    Mar 24, 2008
    20,772
    2,540
    There are a lot of off the shelf stuff that will do this. As Audio Guru suggested, you will have problems with squeal (feedback). Are you wanting to build something or find out where to buy it?
  6. octagonx
    Nov 20, 2008
    6
    i want to build something. i actually have one (purchased one for around $45), and it doesn't suffer from feedback if the speaker is placed at the back of the speaker. Will an 8W amplifier going to be an overkill? I don't have an idea how loud an 8W is..
  7. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
  8. octagonx
    Nov 20, 2008
    6
    I found a 4-ohm 0.5W speaker (the one inside a standard pc speakers). So i'm gonna be using a 1.5W audio amplifier. Would that be ok?
  9. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    No.
    Use a speaker that is rated for more power than the amplifier.
    Alternatively, use an amplifier that is rated for less power than the speaker.
    However, a 1/2 Watt system won't be of any help.
  10. octagonx
    Nov 20, 2008
    6
    What system could be good? Is 1.5W ok? I'll just find a speaker with higher rating.
    Thanks for the info.
  11. floomdoggle
    Sep 1, 2008
    217
    It is not the number of people in the audience that will make the difference, but the size of the room. The more wattage the more the clarity. Volume is independent of wattage. You can turn up any audio amplifier and produce the same volume no matter what the wattage.
    You will want any amplifier capable of 15 - 30 watts driving an 8 ohm,
    8 inch speaker. Any musical instrument store will have cheap vocal range microphones with a wireless sender/reciever. Then just build the amplifier.
    I hope this helps.
    Dan
  12. lespaul
    Jan 30, 2008
    49
    having been a touring sound engineer for...all my life, I would say that this seems kinda impractical. There are too many consumer based mics, amps and audio mixers available to support small meeting rooms of 50-60. If yur inclined to build it then make sure you take gain structure and headroom into account. Otherwise you will have one squealing unintelligible mess.
  13. Audioguru
    Dec 20, 2007
    9,411
    896
    No.
    A powerful amplifier will be able to be much louder than a low power amplifier.
    People near the back of a room will be far from the speaker so the speaker must be loud enough for them to hear it. But the clarity will be bad if the reverberating sounds are the same loudness or louder than the direct sound from the speaker.
