Methodology of a project proposal
Discussion in 'The Projects Forum' started by Hayaalsh, Apr 12, 2014.
  1. Hayaalsh
    Mar 23, 2013
    9
    Hi again :)
    I have to write a project proposal about a DC automatic fan. Im having a trouble with writing the methodology.. I dont know what am I suppose to write?! the instructor said that this section should include
    "how the project will be carried out in terms of development of the circuit and the tests to be carried out."
    I really dont understand what does this means! can someone explain?
  2. R!f@@
    Apr 2, 2009
    8,785
    771
    It means note down everything how the DC automatic fan circuit and explain how the circuit works
    How you go on designing the circuit and ones build, how you test the circuit
    Hayaalsh likes this.
  3. ericgibbs
    Jan 29, 2010
    2,575
    389
  4. Hayaalsh
    Mar 23, 2013
    9
    what kind of tests should I do?
  5. R!f@@
    Apr 2, 2009
    8,785
    771
    Circuit test results are based on what the fan is doing automatic.
    Like when heat rises it switches on and off at predetermined heat ranges. something like tht.
