method of charging any type of battery
Discussion in 'Off-Topic' started by sheldons, Nov 15, 2011.
  1. sheldons
    Oct 26, 2011
    616
    101
  2. t06afre
    May 11, 2009
    5,939
    1,222
    Eh... I hope you understand that this a joke. A good one also:D. But these kind of things belong in off-topic section.
  3. wirednuts
    Nov 13, 2011
    20
    actually you dont need another battery, you can recharge batteries with that method by using the dead battery only.
    in a battery, electrical charge is pushed from one side (+) to the other (-), thats how you get current flow. when the battery is dead, all of the flow is on the (-) side, so to put that back into the (+) side all you have to do is make an electrical bridge between the (-) and (+) sides. i used a golf club. it needs to be something metal and thick, otherwise you will cause a fire much quicker.
    dont do this with the battery still inside the vehicle, you dont want to cause any RF interference with your electronics. its best to put the battery in the middle of a harvested corn field and just drop the golf club on it and run away, as there is a chance of explosion. once you come back, if there is anything left, you will have more energy on the (+) then you did before.
  4. sheldons
    Oct 26, 2011
    616
    101
    if you strip some steel wire armoured cable with wiires connected with sellotape(the supa conducting double sided stuff)to the flat battery and connect it to a 3phase supply and switch on it charges faster.....
  5. ross
    Member
    Jul 30, 2010
    46
    I think its the other way round? Electrons are negative!So there would be no charge on the negative terminal if the battery was dead.
