Meter check of a transistor
Discussion in 'Feedback and Suggestions' started by yoflippo, Apr 20, 2010.
  1. yoflippo
    Apr 19, 2010
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    What kind of meters are you using? I've never tried with a DVM, but VOMs work really well.
    After reading the entire article this will work. Care to pick up the discussion in the Electronics Chat Forum?
  3. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,384
  4. Wendy
    Mar 24, 2008
    20,772
    2,540
    Related, but I suspect the OP hasn't read it.
    To the OP:
    A suggestion, and likely my last word on this subject in this forum, try it on a known transistor to get a feel for the readings and how it works.
  5. AlexR
    Jan 16, 2008
    735
    54
    The OP is correct. The procedure will not work with an a if you are using a digital meter and it is set to Ohms. The meter MUST be set to "Diode test" for it to work.
    The typical digital meter put out around 0.2Volt on the Ohms range which is not enough to forward bias the PN junction.
