I'm using a Fluke 45
It has a Baud rate button , which you can switch from slow , med, or fast
When testing relays, switches , rotary switches to check if there is any voltage change
The Fast Baud rate is used when there is a fast voltage change or when switching a switch or relay fast
But I found using the slow baud rate "captured" the fast voltage changes better, why is that?
When do you use the Fast Baud rate?
why does using the slow baud rate capture better voltage changes ?
