I'm starting to make a very simple brushless DC motor. It's just a single coil and a couple of magnets glued to a needle.
Mechanically it's simple, but the programming will be fun. As expected it won't run stable with just a fixed pulse, so a microcontroller will be working out it's speed and position from the back EMF from the motor so that it can send the pulse at the correct frequency and duty cycle.
Here I managed to get it to run for long enough to see what was happening. It's spinning at about 3800rpm (4 times the speed of the pulses), which is not the aim, but it's enough that I can see it is possible to make it work.
