Messed up ground, solution?
Discussion in 'General Electronics Chat' started by vladtess, Nov 27, 2013.
  1. vladtess
    Jan 5, 2011
    43
    Hello fellas. I have a large building with multiple ground points, some are via copper rods, some are via pipes. However the ground is contaminated: one of the phases is connected to ground so ground (green) wire is always under power (unsafe?). The thing is that I cannot fix it, some rooms are locked so I won't be able to find the source of the problem. Now can I fix it by simply inserting two more rods into surrounding area (and measure resistance) and create a safe ground? Will that create a safe alternative? Thanks much!!!!
  2. MikeML
    Oct 2, 2009
    5,450
    1,066
    Call the power company. They are obligated to fix screw-ups like this. (At least in the USA).
  3. MaxHeadRoom
    Jul 18, 2013
    10,814
    2,491
    Need a bit more information? If one of the phases is connected to ground is this to form a neutral as in one corner of a delta system grounded or is it what is euphemistically known as a wild or high leg system to obtain a neutral?
    In what way is one phase connected to earth ground a danger?
    Max.
  4. Metalmann
    Dec 8, 2012
    700
    223
    I doubt if it helps, but every one of my barns/shops; has an individual ground rod.
  5. MaxHeadRoom
    Jul 18, 2013
    10,814
    2,491
    Or is this a case of a phase being grounded that otherwise is above ground?
    If so it would (should) trip a breaker or blow a fuse if it has a separate grounded neutral?
    A definitive source is SOARES Book on Grounding published by the IAEI (Electrical Inspectors Assoc) Of which the NEC grounding definition is based on.
    This is fairly normal, especially if they have their own service panel.
    Max.
  6. mcgyvr
    Oct 15, 2009
    4,783
    973
    Without knowing your location one cannot give a proper/complete answer.
    In the US you should reference article 250 of the National Electrical Code as well as any other applicable sections.
    Also what is meant by the "ground is contaminated" ?
    You also MUST find the building super or whoever can "unlock" these locked rooms.
    Are you even a licensed electrician?
  7. #12
    Nov 30, 2010
    16,655
    7,293
    Agree!!! This might be a life or death situation. You absolutely must understand the whole circuit or get somebody that does. No guessing allowed!
  8. inwo
    Nov 7, 2013
    2,435
    315
    Don't mess with a corner grounded delta.
    Find a professional who doesn't have to ask.
  9. inwo
    Nov 7, 2013
    2,435
    315
  10. MaxHeadRoom
    Jul 18, 2013
    10,814
    2,491
    From my experience from working with those on other sites, there are still some UN-orthodox methods used out there, it is not the fault of the person having to operate with the system.
    Max.
  11. vladtess
    Jan 5, 2011
    43
    Basically when I measure ac voltage between the ground and hot terminal I get 120 volts
  12. MaxHeadRoom
    Jul 18, 2013
    10,814
    2,491
    In common conditions that is normal?
    The complete configuration would have to be known.
    What is your country/location etc.
    Max.
  13. inwo
    Nov 7, 2013
    2,435
    315
    True.
    Repairs to an unknown system by an inexperienced person is another story.
  14. vladtess
    Jan 5, 2011
    43
    We'll I'm not sure about configuration. Just thought that this May not be normal and looking for ways to fix it. I'm in New York.
  15. MaxHeadRoom
    Jul 18, 2013
    10,814
    2,491
    Then in a normal installation such as in a residential or apartment situation, this is normal.
    Could be nothing to fix?;)
    Max.
  16. mcgyvr
    Oct 15, 2009
    4,783
    973
    oh boy..
    Just stop now before you kill yourself or someone else.
    If there is any need for electrical inspection/modification in that building you MUST call a licensed electrician.
    This isn't a job for you..
  17. inwo
    Nov 7, 2013
    2,435
    315
    I rest my case.
  18. MaxHeadRoom
    Jul 18, 2013
    10,814
    2,491
    Just curious, What was your involvement with this in the first place that gave you a reason for concern?
    Max.
  19. GetDeviceInfo
    Jun 7, 2009
    1,571
    230
    your 'phase' wouldn't happen to be colored white would it?
    inwo likes this.
