message "demo limit" in mikroC
Discussion in 'Embedded Systems and Microcontrollers' started by saman1969, Dec 30, 2012.
  1. saman1969
    Nov 2, 2012
    15
    When my program is compiled the compiler show error message "Demo limit" .
    my program is run in mikroC v.5 . and finaly it should be programmed on the DSPIC(33F256GP710) .it appears that when my codes passes from a limit it occures.but the number of line in my code is about 850 and it seems to be not very larg . please giude me in this problem
    thanks
  2. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,384
    saman1969 likes this.
  3. DerStrom8
    Feb 20, 2011
    2,428
    1,329
    850 lines is much too large for the mikroc demo. You'll probably either have to purchase a license for the full version of mikroc, or switch to a free compiler. You may want to check the Microchip website to see what compilers they have for that type of chip.
    Good luck!
    Matt
  4. hexreader
    Apr 16, 2011
    250
    82
    The demo limit is reached at 2k program words.
    A line of C code may be any number of program words.
    Clearly your 850 lines of C code exceeds 2k program words.
    The options that come to mind are:
    1 Write less code
    2 Write more efficient code
    3 Buy a licence
    Latest version of C compiler is mikroC pro version 5.8
    EDIT: I am way too slow - everyone else got there first
  5. saman1969
    Nov 2, 2012
    15
    if I compile my program it will face with "Demo Limit" message and when I disable a line of it , it will compiled successfuly and make a hex file with size 24KB . it seems deleting one line does not reduce so large size down to 2k (that is the limit of demo version of mikroc). I use full version of the mikroC not demo.
    please help me my friends.
    thanks
  6. be80be
    Jul 5, 2008
    432
    57
    If you have a full version of MiKroC I would be Calling them not over here asking for help
    I would be asking for my Money back on the phone or Fix it till I get what I paid for.
  7. spinnaker
    Oct 29, 2009
    5,065
    1,160
    You might think you are running the full version but obviously you are not.
    Check on this page
    http://www.mikroe.com/mikroc/pic/
    In the lower right hand corner. It explains the license key. I don't run mikroC and was able to find this in a 2 minute search. Not sure whayyou were not able to find it.
  8. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,384
    DerStrom8 and spinnaker like this.
  9. DerStrom8
    Feb 20, 2011
    2,428
    1,329
    I was thinking the same thing. If you pirated this program, then obviously you're getting what you paid for. It never pays to use cracked programs, and in fact does much more harm than good, even to yourself. If that is indeed the case, let this be a lesson for you. I suggest searching for alternative options that are actually legal.
    Regards
  10. be80be
    Jul 5, 2008
    432
    57
    It's more then likely A hacked IDE or the phone would be ringing If he bought the real thing
    The Op wouldn't be asking for help here to fix it.
    Kind of like a guy got a clone of the pickit2 and then ask Microchip it fix it. Not happenning
    so where do they any forum that may help.
