The Electrician
- Joined Oct 9, 2007
- 2,970
You can use the mesh method to solve this. Once you get a solution for i1 and i2, then Vo is given by Vo = i2*Rc. The expression for i2 will involve Vin and then Vo/Vin can be determined.I'm trying to figure out what I did wrong...
Is the circuit attached to this post correct? (See figure)
Should I be able to derive the transfer function from this representation of the circuit?
What did I do wrong previously?
You have two meshes here, but the currents i1 and i2 aren't independent; in fact, i2 = -β*i1, so you really have only one mesh equation; the other equation needed is a constraint equation.
The first (and only) mesh equation is (rp1+Z)*i1 - (Z)*i2 - Vin = 0
The constraint equation is (β)*i1 + (1)*i2 = 0
You should be able to solve those and get an expression for Vo/Vin.
Later you can give the nodal method a go.
