Mesh current analysis question
Discussion in 'Homework Help' started by SSM1, Oct 17, 2010.
  1. SSM1
    Oct 17, 2010
    In class I asked my professor whether mesh current loops could enclose resistors in a linear circuit (That is, extend over multiple mesh current loops). He said that this is allowable and the mesh current equations can be solved be appropriately picking the loops. However, a few different textbooks require that the current loops do not enclose any resistive elements. Is my professor corrrect? If not, can anyone offer an example where extending current loops over resistors does not work?
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    I guess one has to firstly satisfy the general requirement that for a circuit with b branches and n nodes one requires m= b-n+1 independent mesh equations to solve the for the necessary circuit conditions. Provided the m selected mesh current paths are independent one can conceivably have a number of options for the particular independent paths.
    I'm unsure of the meaning of enclosed resistor branches and their relevance to the matter.
    One can easily test this by drawing a circuit and solving it with a few different loop configurations and possibly with loops which "enclose a resistor branch".
  3. The Electrician
    Oct 9, 2007
    2,301
    339
  4. SSM1
    Oct 17, 2010
    For example,
    http://www.allaboutcircuits.com/vol_1/chpt_7/1.html
    In the example with parallel resistors, one possible current loop could be drawn in 1-3-6-8. In this case, resistor R1 is enclosed within the loop. My question is whether using this current loop is permissible in mesh current analysis and if not, why.
  5. t_n_k
    Mar 6, 2009
    5,448
    783
    A simple parallel circuit like that wouldn't necessitate a mesh analysis approach - but yes you could select that loop as one independent case.
    That circuit really only has two nodes and two branches. Any branch current can be 'solved' with a single independent equation.
    Take the circuit in my attachment as a more realistic example. I have shown just two loop selection options - there are others.
  6. t_n_k
    Mar 6, 2009
    5,448
    783
    Oops! I should be more careful - that should be four 4 branches and two nodes.
  7. renotenz
    Oct 25, 2010
    11
    Well, if you do that "resistor-enclosing thing", it's more like you used KVL method rather than a mesh analysis.
    If your professor told you that it is permissible, then you may just use it, since mesh analysis actually use KVL method anyway...
    The difference is just that mesh analysis requires you to find currents in each loop first before looking for currents in each resistive elements, whereas KVL method allows you to find currents in each resistive elements without a need to find current in each loops.
