Mesh Current Analysis Problem Help
Discussion in 'Homework Help' started by crazyengineer, Dec 31, 2010.
  1. crazyengineer
    Dec 29, 2010
    156
    Hi I need some help trying to solve IO in this mesh current analysis problem. Element E is a 5 volt power supply with the + at the top. What I originally did....
    Set mesh 1 (ia) in the left loop as
    10=5000ia-10000ia+10000ib
    and mesh 2 (ib) in the right loop as
    5=10000ia-10000ib-4000ib
    after algebraic manipulation I found ia=.004167a and ib=.006333. Then I subtracted ia from ib and thought io=-.002167. However, the book's answer was -.136ma. Please help!
  2. kira12a8
    Dec 31, 2010
    Your equation is wrong man. It's must be :
    15000Ia - 10000Ib = 10
    -10000Ia + 14000Ib = 5
    Calcultes it then substracts you will get the right answer -136mA :D
    crazyengineer likes this.
  3. Jony130
    Feb 17, 2009
    3,993
    1,116
  4. crazyengineer
    Dec 29, 2010
    156
    hmmmm I understand how mesh b is -10000Ia + 14000Ib = 5, but I'm puzzled about how mesh a is 15000Ia - 10000Ib = 10. Isn't the it -5000ia+10+10(ia-ib)?
  5. Jony130
    Feb 17, 2009
    3,993
    1,116
    I like to write it in this way
    -10 - 10000 (Ia - Ib) - 5000 Ia = 0
    -4000Ib - 5 - (Ib - Ia) 10000 = 0
    Io = - 3/22000 = 136.363636uA
  6. crazyengineer
    Dec 29, 2010
    156
    Hmmm. I'm sorry if I'm still asking questions about this problem, but I want to fully understand this method.
    From what I read, I thought that traversing the loop should be in a clockwise direction, so I thought that it would be -5kia since it's going negative to positive, then 10v since it's going positive to negative then positive 10k(ia-ib) since it's going positive to negative.
  7. Jony130
    Feb 17, 2009
    3,993
    1,116
    Read the link I post
    "The choice of each current's direction is entirely arbitrary"
  8. crazyengineer
    Dec 29, 2010
    156
    OOO! I see now. Thank you everyone!
