mesh analysis
Discussion in 'Homework Help' started by assenav, Aug 15, 2009.
  1. assenav
    Aug 9, 2009
    find the value of V using kirchoff's law and mesh analysis.all resistances aregiven in kilo ohms
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    Hi Assenav,
    You might consider posting some of your work - even if you don't have much of an idea where to begin.
    Even if you don't use conventional mesh analysis you might work out a solution.
    For instance, you can make a good case for saying that the current (I2) in the 0.5 Ω resistor is 41xI1.
    You can then use Kirchoff's voltage law to write the loop equation for the left hand loop entirely in one unknown - i.e. I1
    Then you will be able to solve for I1 and then this will lead to another loop equation for the right hand loop in which V is the sole unknown. Then you have V.
