Probably the easiest is to bring up both designs and then copy and paste the schematic from one schematic window to the other.
Hi
Open both schematics.
Click anywhere on the "From" schematic.
Click the tool on the toolbar that looks like two documents. The cursor will change to "two documents".
Select the objects you want to copy. The objects will drag around with the cursor indicating the selected objects.
Click anywhere on the "To" schematic. The objects will then show attached to the cursor.
Click where you want to place the objects.
That's it!.
I'm running W7pro and this works for me:Say I have 2 different LTSpice designs (asc files) File1.asc, file2.asc. I want to merge the design from file1.asc, into file2.asc. Is there anyway to do this? Basically I want to copy the design from File1.asc to file2.asc.
1) Load file2.asc
2) Load file1.asc
3) Use COPY to select what you want from file1.asc
4) At this point you'll have two menu options; choose file2.asc.
5) Paste what you got from file1.asc into file2.asc.
"Copy" and " Pasteworks forI got it already. Thanks.
And there is no COPY. That is what is misleading about LTSpice. It is Duplicate.
What?"Copy" and " Pasteworks for
Isn'I got it already. Thanks.
Steady there, my friend. Frustration is allowed with inanimate objects. LTSpice isn't going to need therapy because of Spinnaker's "bullying".I don't think you got it already, since you're badmouthing LTspice for no reason other than to assuage your own ego.
Indeed. Thank you for the reality check.Steady there, my friend. Frustration is allowed with inanimate objects. LTSpice isn't going to need therapy because of Spinnaker's "bullying".
