memristor project problem on netlist code ! (spice)
Discussion in 'The Projects Forum' started by saha33, Jun 19, 2013.
  1. saha33
    Jun 19, 2013
    Hi all,
    I have a project about memristor based phase shift oscillator. I have wrote a spice code. I suppose that, It has some problems about subcircuit usage and library definition.
    If you can help me to work this code I appreciate. The code can be seen below.
    *Libraries:
    * Local Libraries :
    * From [PSPICE NETLIST] section of C:\Program Files\Orcad\PSpice\PSpice.ini file:
    .lib "nom.lib"
    X_U1A 0 N00542 N01372 N01457 N00895 AD648A
    R_R1 N01002 N00542 1.3k
    R_R2 N00542 N00895 37.7k
    X_memristor 0 N00575 1k 100k 80k 10f 1 memristor
    R_R4 0 N00633 1.3k
    C_C2 N00575 N00633 0.5u
    C_C3 N00633 N01002 0.5u
    V_V1 N01457 0 -12Vdc
    V_V2 N01372 0 12Vdc
    C_C1 N00895 N00575 0.5u
    .tran 0 1 0 1.0001
    .SUBCKT memristor Plus Minus PARAMS:
    + Ron=1K Roff=100K Rinit=80K D=10N uv=10F p=1
    *STATE EQUATION MODELLING*
    Gx 0 x value={I(Emem)*uv*Ron/D^2*f(V(x),p)}
    Cx x 0 1 IC ={(Roff-Rinit)/(Roff-Ron)}
    Raux x 1G
    * RESISTIVE PORT MODELING*
    Emem plus aux value ={-I(Emem)*V(x)*(Roff-Ron)}
    Roff aux minus {Roff}
    * WINDOW FUNCTION MODELLING*
    .func f(x,p)={1-(2*x-1)^(2*p)}
    .ENDS memristor
    .END
    It gives some error such as " ERROR -- Incorrect number of interface nodes for X_memristor"
    This work done in the article (http://link.springer.com/article/10.1007/s13204-011-0021-4#page-1)
