Memory in circuit logic
Discussion in 'The Projects Forum' started by jlatshaw, Sep 2, 2014.
  1. jlatshaw
    Jul 20, 2013
    28
    So for a project, I am attempting to make a circuit able to record some integer values (from inputs) and then make decisions based off of their values (return which input gave the highest input) .
    My question is, how can I best store values with a digital logic circuit? I was thinking that I could use flip flops to store values, but I am trying to find the best way to go about this. Any suggestions?
    Thanks,
    James
  2. MrChips
    Oct 2, 2009
    12,633
    3,453
    The best way would be to use a microcontroller.
  3. djsfantasi
    Apr 11, 2010
    2,905
    878
    How many is "some", so we can have an idea of how to "best store" them?
    And are you looking at one set on inputs or multiple sets?
    And how large are your integer inputs (how many bits are required to store and compare)?
    Without specific requirements, I can think of several suggestions, none of which may be applicable.
  4. jlatshaw
    Jul 20, 2013
    28
    Thanks for the replies.
    I agree that a microcontroller would probably be best, but I am trying to challenge myself and see if I can do this project without one.
    And I would like to store multiple 6 bit values from various inputs. However, we can simplify the process for now and assume there is only one 6 bit input.
    Thanks,
    James
  5. crutschow
    Mar 14, 2008
    13,496
    3,373
    You could use a 74VHC573 8-bit (octal) latch to store the 6-bit value for each input. That would require one IC per 6-bit word.
  6. jlatshaw
    Jul 20, 2013
    28
    Thanks for your input.
    But as a follow up question, what are the main differences between the various kinds of flip flops (such as D-latch and SR)?
    In particular, how is the one more useful than the other?
    Thanks so much, you all are very helpful,
    James
  7. bertus
    Administrator
    Apr 5, 2008
    15,801
    2,386
  8. tshuck
    Oct 18, 2012
    3,531
    675
    Which is more useful depends on the situation. The two most popular are D flip flops and JK flip flops.
    Each has their own characteristics that are useful in various situations.
  9. pwdixon
    Member
    Oct 11, 2012
    488
    56
    As someone else already said use a micro. I've been designing electronics for 40 years and in the early days logic was all we had, that was just before micros came along. I can pretty much say that in the last 10 years or more I haven't touched a logic chip, everything (other than absolutely single logic chip circuits) can be done simpler, more flexible and cheaper using a micro unless you are looking for some high speed parallel processing and even then multi-processor solutions are my first go-to.
  10. jlatshaw
    Jul 20, 2013
    28
    Thanks for the input and advice everyone.
    You all are super helpful.
    -James
