Memoriam for a friend
Discussion in 'The Projects Forum' started by Scarfoot, Jun 10, 2013.
  1. Scarfoot
    Jun 10, 2013
    I have a friend who passed away. I wanted to make a little tribute to him for my bar. This would be the Tachometer from his bike mounted on the bar. I wanted it to light, and show a tach of between 1200 and 3000 rpm. I was hoping to run it off AC current. The problem is, I am not tech savy. It is my hope this would be a fairly simple project and someone here could guide me on it.
    Thanks in advance.
  2. Dodgydave
    Jun 22, 2012
    5,143
    768
    So its a 12 Volt tacho then? if so 3000RPM is a 50Hz square wave signal to the sense pins,so 25Hz is 1500RPM. You can use a 555 timer as an oscillator, select the resistor /capacitor values to give out 20 to 100Hz.
    OR you could put a low voltage AC supply to the sense pins if its 50Hz = 3000RPM / 60Hz = 3600RPM
  3. Scarfoot
    Jun 10, 2013
    It is indeed a 12 volt. There are four wires, red, yellow, green, and black. The black appears to be the ground wire. The safest way sounds like the low voltage AC supply.
