Medium to High voltage variable power supply
Discussion in 'The Projects Forum' started by lordofentropy, Dec 18, 2014.
  1. lordofentropy
    Thread Starter Active Member
    Apr 10, 2010
    52
    Hello all,
    I am currently trying to procure a single phase transformer for a variable power supply. Some design constraints, single phase...120 VAC in, output needs to be anywhere from 650 VDC to (really no upper limit, however it will not be set any higher then 600) with max 1A current output. Does anyone have any links/suggestions to find this guy? Further more, any general sites that have high power components? I.E. 30KV rated Capacitors, etc. that is not necessary ebay.
  2. DickCappels
    Aug 21, 2008
    2,773
    669
