Medium frequency receiver
Discussion in 'Wireless & RF Design' started by squb, Jun 29, 2013.
  1. squb
    Jun 29, 2013
    Hello all.
    I have problem with designing radio receiver which working on one frequency 457 kHz. I realize that I could use standard medium frequency radio receiver scheme
    and adjust circuit for 457 kHz.
    I would like to ask you guys ,if it is possible to build such a circuit where mixer and frequency conversion to 455 kHz is not used.
    I would like to try build circuit where signal (CW modulation) is received by by ferrite rod antenna then signal is toward to band pass filter ,then to class C power amplifier and then to A/D converter embedded in MCU.
    Do you think above circuit has chance to work ?
  2. wmodavis
    Oct 23, 2010
    737
    150
    "I have problem with designing radio receiver which working on one frequency 457 kHz. I realize that I could use standard medium frequency radio receiver scheme and adjust circuit for 457 kHz.
    I would like to ask you guys ,if it is possible to build such a circuit where mixer and frequency conversion to 455 kHz is not used. YES!
    Do you think above circuit has chance to work I do not see a circuit above.
  3. Ramussons
    May 3, 2013
    561
    92
    Can you lay your hands on an old AM/SW receiver? The ones that used transistors? The IF amplifier used in these Radios were of 3 stage tuned to frequencies between 455 and 470 KHz. Re tune them and they will serve your "receiver" requirements.
    Ramesh
