mechanically coupled DC motors
Discussion in 'General Electronics Chat' started by dmta, Mar 27, 2013.
  1. dmta
    Mar 24, 2013
    32
    Hi all,
    I am building a DC motor control demonstration pannel. Apart from controlling the speed I also want to simulate a load acting on the DC motor. Hence I thought of coupling another DC motor to the existing one and rotating it in the opposite direction Just like in the figure.
    If we say that motor A is the motor to be controlled (clockwise) and B is the torque generator, even though B is given power to rotate anti clockwise it will always be rotating in the opposite direction because of A. This will cause B to heat up and I fear that it would get burnt.
    The goal is to somehow dissipate the current generated by B. can you all help me.
    BTW both motors will be driven by H-bridges and both will have speed measuring ability.
    Thank you !!!!!!!!!!!!!!
      File size:
      8.8 KB
      17
  2. timescope
    Member
    Dec 14, 2011
    298
    44
    You would need a fluid or friction type of coupling to mechanically couple two shafts rotating in opposite directions
    A better idea would be to use motor B as a generator and vary the load on it.
    Timescope
    shortbus likes this.
  3. shortbus
    Sep 30, 2009
    4,096
    1,692
    A pot/rheostat between the brushes of motor B would also work. Many motor braking systems use this.
  4. dmta
    Mar 24, 2013
    32
    Hi every one !!!!!
    I am VERY SORRY for this late reply.
    Even though I asked this question a while back I am trying to implement it just now and I have a problem with selecting the motors.
    Should I chose same motors for A and B or are there other factors that I have to weigh in?
    Also, should I choose high power motors to get practical load resistor values?
