Mechanical switch in LTspice
Discussion in 'General Electronics Chat' started by cmartinez, Apr 15, 2015.
  1. cmartinez
    Thread Starter AAC Fanatic!
    Jan 17, 2007
    3,700
    2,802
    I'd like to use LTspice to simulate how a mechanical switch produces a spike in voltage when it is opened while driving an inductive load.
    Can it be done?
  2. OBW0549
    Mar 2, 2015
    1,396
    941
    I haven't used it myself, but you might try the sw (voltage-controlled switch) component, driven by a PWL or PULSE voltage source.
    cmartinez likes this.
  3. crutschow
    Mar 14, 2008
    13,527
    3,393
    LTspice has a voltage controlled switch model (sw) that will certainly generate a spike with an inductive load.
    You need the sw model discription for the switch to work (look up "sw" in the help file).
    You add it as a Spice directive (hit the S key while in the schematic window) .
  4. MikeML
    Oct 2, 2009
    5,451
    1,066
    Here is something I did some time ago...
    DickCappels and cmartinez like this.
  5. cmartinez
    Jan 17, 2007
    3,700
    2,802
    Very, very interesting. Thank you both.
    I just found the Vswitch.asc example included in LTspice and am finding it quite useful.
    My only issue with it is that it's a voltage controlled switch... is there no other kind of switch that could be timed during the simulation? But maybe that's not important since I can always configure a voltage source to drive it.
    Thanks again!
  6. cmartinez
    Jan 17, 2007
    3,700
    2,802
    Excellent file Mike! Thanks for posting.
  7. MikeML
    Oct 2, 2009
    5,451
    1,066
    It is easy to make the switch state a function of time, a voltage, a current, etc...
  8. cmartinez
    Jan 17, 2007
    3,700
    2,802
    Would you please share with me your definition of easy? I'm a neophyte in most LTspice-related things... need to find an example of making a switch a function of time... or maybe I just need more experience with the spice-directive instruction.
  9. MikeML
    Oct 2, 2009
    5,451
    1,066
    The sim I just posted makes the switch state a function of time because the controlling voltage V(pulse) is a function of time. By default, the switch is closed when the input voltage is >0V, and is off if the input control voltage is <=0V. If you prefer it to have a different Threshold voltage, you can set it in the .model SW statement. You can model a switch with hysteresis, too.
  10. cmartinez
    Jan 17, 2007
    3,700
    2,802
    Yeah... that's more or less what I meant on post #5 ... but you've given me even more information now, thanks.
  11. cmartinez
    Jan 17, 2007
    3,700
    2,802
    Hello all... I just found the time function in LTspice, and I'm using it to change resistor or pot values (or any value for that matter) during the simulation. In the case of a resistor, for instance, one only has to change its value to:
    R=if(time<10m, 5, 15)
    Alternative:
    R=table(time,0,5, 10m,5,10.01m,15, 20m,15, 20.01m,25)
    You can make nested if() of course.
    R=if(time<10m, 5, if(time<20m,15, 25))
    EDIT: will next try it with the switch
    Sinus23 likes this.
