Hi all, i've been tasked to activate a vibrating plate using a sensor. Both are connected to the mains but the sensor uses a step down to 24Vdc. Currently i'm trying to connect them using a relay but i do not know how to connect them. On the relay there are, (+ve) (-ve) Com, NO and NC.
The sensor has one wire as output while the vibrator has one yellow and 2 black wires. Can someone pls tell me if i'm correct to use a relay? and also which wire goes to which part of the relay? thank you!
