Mechanical Engineer Needs Help with Switching
Discussion in 'General Electronics Chat' started by colewelch, Sep 26, 2016.
  1. colewelch
    Sep 26, 2016
    Hey Everyone!
    I have a fairly simple circuit that uses a momentary switch and a latching relay to activate a solenoid. I am trying to change this circuit so the operator has to hold the momentary switch for 3-5 seconds before the signal is sent to the solenoid. What would be a simple way to do this?
    Thank You!
    Cole
  2. MaxHeadRoom
    Jul 18, 2013
    10,867
    2,528
    You could use a simple 555 timer which could also energize the relay, is the relay a self latching type?
    Max.
  3. crutschow
    Mar 14, 2008
    13,521
    3,388
    Depending upon the relay coil voltage and current, it could be as simple as adding a transistor, resistor, diode, and capacitor.
    What is the relay coil voltage, current, and type (AC or DC coil)?
  4. GopherT
    Nov 23, 2012
    6,333
    4,082
    A $7 dollar Arduino and a USB cable to program it. It may be overkill on the hardware but the price includes the board to connect your I/O wires and you get to try countless options without re-soldering anything.
  5. colewelch
    Sep 26, 2016
    Thank You guys for the help!
  6. MaxHeadRoom
    Jul 18, 2013
    10,867
    2,528
    So what is the decision?;)
    Max.
  7. colewelch
    Sep 26, 2016
    I went with a Crouzet timer able to handle the 24VDC I am using in the clamping system.
