To keep things simple, I will ask the question first and give the background later.
The question is: What leakage resistance would you expect between the pads of a 1206 size part on a fiberglass PCB. Assume that the board does not have solder mask and has been thoroughly cleaned using isopropyl alcohol and is at 50% relative humidity.
The cap does not appear to be the limiting factor since I have seen spec's for a ceramic SMD cap having as much as 10,000 Meg ohms of resistance.
The background:
I am considering building a version of the Atansoff Berry Computer (ABC) using CMOS logic instead of over 300 vacuum tubes and thyratrons (or even discrete MOS-FET's).
https://en.wikipedia.org/wiki/Atanasoff–Berry_computer
What intrigues me right now is the memory system that was used. It was mechanical and stored the bits as charges on a bank of capacitors. The caps were selected by a motor-driven rotary switch.
https://en.wikipedia.org/wiki/Regenerative_capacitor_memory
I would like to do my initial testing at slow speed -- ideally without a motor. To do this, I need to store the charge on the caps for a very long time. It would be nice if this time was on the order of tens of seconds. This would allow me to manually enter the bits using switches and view the data using an LED. For the initial tests I will use a 10 position switch but eventually I would make a PCB switch. The PCB switch would have something like 50 caps and contacts plus a motor driven wiper mechanism. Lots more work needed here...
The background:
