measuring wind turbine power
Discussion in 'General Electronics Chat' started by hello14, Dec 18, 2010.
  1. hello14
    Dec 18, 2010
    I have a 3 phase AC wind turbine that is directly connected to 3 pieces of same ligthbulbs. here is the picture (http://img232.imageshack.us/f/photol.png/)[​IMG][​IMG]. I'm wondering how should I compute for the power generated by the turbine.
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Obtaining a measure of both voltage and current across a load will give you power. Power is the product of those measurements.
  3. hello14
    Dec 18, 2010
    do I need power factor or √3 (squareroot) ?
  4. thatoneguy
    Feb 19, 2009
    6,357
    718
    If you have a True RMS meter, you will get the real voltage and real current through each bulb. Multiply them for real power.
    A non True RMS meter will give a close voltage if the input is an undistorted sine wave (which yours is), you can do the same math.
    You only need to worry about 1.404 and 0.707 when converting between peak and RMS or vice versa.
  5. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    You can always go through a full wave rectifier and deal with DC.
  6. thatoneguy
    Feb 19, 2009
    6,357
    718
    This would work if it was filtered. Would need to be cautious on what voltage caps to get. Make sure you get caps rated for over the Peak Value.
    I'm guessing this test is to get an idea of the voltage and power the windmill outputs, a home made one, is this correct?
  7. timrobbins
    Aug 29, 2009
    318
    16
    hello hello,
    As per above, you need to calculate the power through each bulb by V x I. You then need to sum the three measured power levels.
    If the bulbs are the same type then you could make an assumption for turbine power as 3x the power measurement for one bulb.
    Bulbs are non-linear loads so you can't use the bulb power rating. Bulbs will fail very quickly if you apply more voltage across the bulb than the rated bulb voltage (very easy situation to occur with a wind turbine, and can lead to ugly consequences as the turbine is then unloaded).
    Ciao, Tim
