Measuring Voltage up to 4 decimal places using TDS3032 Oscilloscope
Discussion in 'General Electronics Chat' started by Tahsina Hossain, May 11, 2015.
  1. Tahsina Hossain
    Jan 16, 2015
    40
    Hi Everybody,
    I am trying to capture waveform data from TDS 3032 oscilloscope through RS232 port. All samples have 1 decimal place data only (i.e. 20.3V) whereas I need something like 20.2985V. Is there any way to get 4 decimal places from oscilloscope?
    I really appreciate any help.
    Tahsina
  2. MrChips
    Oct 2, 2009
    12,652
    3,461
    No way. Most digital scopes are 8 or 9-bit resolution.
    The TDS3032 is 9-bit vertical resolution, that is 1 part in 500 resolution.
    Do the math. Four decimal places such as 20.2985 is a resolution of 1 part in 200,000.
    You would need an 18-bit ADC and less than 100μV noise.
    Tahsina Hossain likes this.
  3. crutschow
    Mar 14, 2008
    13,523
    3,390
    To get higher resolution you would need a fast, high resolution digitizer (A/D converter). But you likely won't be able to reach 18 bits.
    What is the highest frequency of interest in your signal?
  4. Tahsina Hossain
    Jan 16, 2015
    40
    Thanks a lot for your reply. Can you suggest any oscilloscope that can do this?
  5. Tahsina Hossain
    Jan 16, 2015
    40
    Well, the voltage signal is 50Hz. Is this what you are asking?
  6. crutschow
    Mar 14, 2008
    13,523
    3,390
    Yes. That eases the problem somewhat.
    So why do you want such high resolution for a 50Hz signal (I presume this is the main's voltage)?
  7. MrChips
    Oct 2, 2009
    12,652
    3,461
    I am not aware of any oscilloscope with that kind of resolution.
    You need to find a DAQ system. Search google for high resolution DAQ.
  8. Tahsina Hossain
    Jan 16, 2015
    40
    Basically I have a sense resistor (0.156ohm) at an inverter output. I am using two probes to acquire voltage level before and after the sense resistor so that I can deduct one from another to get the voltage drop across the sense resistor. The objective is to find inverter output current. However, since I am getting only one decimal place, the two probes are giving something like 19.5V and 19.4V but this is not giving me proper voltage drop. According to my theoretical calculation, the inverter output current is 62mA, which means there should be 0.009672V drop across the sense resistor. I hope I could explain my problem to you.
  9. MrChips
    Oct 2, 2009
    12,652
    3,461
    Leave the two probes where they are and select the MATH SUB feature of the oscilloscope.
  10. Tahsina Hossain
    Jan 16, 2015
    40
    That is the obvious thing to do, right? So I tried that a lot of times. The probe voltages are almost similar in amplitude (around 20V) which means the result of MATH function is a very low voltage (milli-volts). So when I change the vertical volts/division to milli-volts level, say 100 mV/division what I see in the scope is almost like a noise rather than expected outcome. I captured the data (which seemed like noise) and observed manually that the data values are not consistent, means its noise plus data as the data is at milli-volts level. What can I do?
  11. MrChips
    Oct 2, 2009
    12,652
    3,461
    Have you tried using a DMM to measure the voltage across the resistor?
  12. crutschow
    Mar 14, 2008
    13,523
    3,390
    You can't change the scale to mV levels when using the math function since that causes the the scope input amplifiers to saturate.
    You need a differential amplifier with good common mode rejection at a high voltage to measure that voltage. TI, among others, sells such amps.
  13. Tahsina Hossain
    Jan 16, 2015
    40
    Hmm, seems like I am out of options at hand at the moment :-(
  14. crutschow
    Mar 14, 2008
    13,523
    3,390
    Why not use a DMM?
  15. Tahsina Hossain
    Jan 16, 2015
    40
    I have fluke 39 but it cant measure current below 1A, my output current should be around 62 mA
  16. DickCappels
    Aug 21, 2008
    2,785
    676
    You might want to use a high accuracy DMM to measure the voltage across the resistor.
  17. tcmtech
    Nov 4, 2013
    2,120
    1,754
    You could just change the resistor out to a larger value one and increase the voltage drop across it or you could do a direct millivolt reading across the resistor and calculate your current from that.
  18. Tahsina Hossain
    Jan 16, 2015
    40
    Hi, exactly what I did last night and things seem to work now. Thanks a lot for your great suggestion.
