measuring voltage of cells in series
Discussion in 'General Electronics Chat' started by fredp, Sep 24, 2009.
Thread Status:
Not open for further replies.
  1. fredp
    Thread Starter Active Member
    Sep 24, 2009
    41
    I am using a voltage scaling circuit to measure the voltages of a bunch of voltaic cells in series. For some reason, the circuit below doesn't work. Each individual meter and resistor set works if connected to a single battery, buy when I connect the next one in the chain, weird stuff starts to happen, like a negative voltage is displayed on the meter.
    Thanks for any advice
  2. studiot
    Nov 9, 2007
    5,005
    515
    Consider parallel paths. Does this sketch help?
  3. fredp
    Sep 24, 2009
    41
    No, I'm not really sure what you are trying to point out. Does the circuit I posted seem like it should work? It seems fine to me one paper. I can't figure out what the problem could be.
  4. SgtWookie
    Jul 17, 2007
    22,183
    1,729
    Fredp,
    I don't see anything "wrong" with your schematic.
    Are you certain that you connected the cells as shown in your schematic?
    Sometimes if cells become too deeply discharged, they can reverse polarities. However, with 2 megohms (total) across each cell, that should take quite a while.
  5. bountyhunter
    Sep 7, 2009
    2,498
    507
    The 1.8M resistor is in series with the parallel of 200K and the meter, so there will be ahuge voltage drop across the 1.8M (90% drop). Are you scaling up to compensate for that?
    I don't see anything that could cause negative readings.
  6. Tesla23
    May 10, 2009
    323
    67
    Are all the CX101B's all fed from a common power supply? I suspect that this device doesn't have an input truly floating from the supply. From a quick search on CX101B:
    The CX101A & CX101B are designed to be used with an independent (isolated) ground. The signal being measured cannot share a common ground with the supply voltage for the panel meter.
  7. fredp
    Sep 24, 2009
    41
    Yes, the cells are powered by an independent 5 V supply, and the measured signals are D-cell batteries at the moment. I can connect 2 in series, but connecting the third makes the first one read incorrectly.
    The strangest part is that if I measure the voltage across the scaling resistor, it is correct. This leads me to believe that the meters are somehow affecting each other.
    The meters are wired as illustrated on the right side of the second page of this pdf:
    http://www.circuitspecialists.com/images/CX101-1.pdf
  8. fredp
    Sep 24, 2009
    41
    Well, the resistors scale the 1.5 V signal to 0.150 V--since the meters have a range of 0-200 mV. The decimal place on the meter is adjusted accordingly. The meters and circuits work perfectly when I only measure individual cell voltages. Things fall apart when measuring multiple cells in series.
Thread Status:
