measuring very small current
Discussion in 'The Projects Forum' started by umer27, Mar 10, 2009.
  1. umer27
    Feb 28, 2009
    25
    Hay all , Im using a 0.1 Ohms @ 3 watts (wire wound resistor) as a shunt for measuring current of a solar panel...
    Its a 10W solar panel.. , Isc=0.7 A and I hope to accurately determine the current as accurately as possible..
    Im using an ATmega8 AVR controller , with a 10 bit ADC on it..
    As, V=IR,
    in my case...
    Imax= 1 A (its ~700mA but lets say for simplicity)
    Voltage = 0.1 x 0.7 =0.07 V
    So, using an op-amp with a gain of 71, gives me .... 0.07 x 71 = 4.97V
    I think I would have problems with differentiating such a small signal as lets say I wanted to measure a difference in current of say 5 mA ... I will use an instrumentation amp for better results ... but ..
    the question is should I use a larger resistor, so I can measure the current more accurately .. (I know losses would increase but I am willing to trade that for higher current accuracy..)
    has anyone ever measured differences in current as small as 1-5 mA ?
  2. KL7AJ
    Nov 4, 2008
    2,043
    292
    Use a teeny-tiny meter. :D
  3. KL7AJ
    Nov 4, 2008
    2,043
    292
    In all seriousness, that can be done with a simple passive analog meter. In fact, microammeters are readily available.
    eric
  4. mik3
    Feb 4, 2008
    4,846
    63
    A larger value resistor will give more accurate results because its resistance its not close to the wires resistance and the wires won't affect the measurement significantly. Also, a bigger voltage will be dropped and it will be less affected by noise.
  5. umer27
    Feb 28, 2009
    25
    how large are we talking here... Im thinking 1 or 2 Ohms should be enough..
  6. umer27
    Feb 28, 2009
    25
    Loss at 1 Ohms..
    P= square(0.7) * 1 = 0.7 Watts
    @ 2 Ohms.. its 1.4 Watts.. not bad, since I have to measure the current for a very small amount of time..
  7. umer27
    Feb 28, 2009
    25
    and If I do this, can I measure current differences as small as 1 mA ?
  8. umer27
    Feb 28, 2009
    25
    PS, im using the current value in my microcontroller.. so any teeny tiny meters wont do..
  9. mik3
    Feb 4, 2008
    4,846
    63
    If you set the reference voltage of the ADC properly you will be able to detect voltages of less than 1mV.
  10. umer27
    Feb 28, 2009
    25
    set the voltage reference properly ?
  11. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    Stick with the original resistor.
    1mA = 0.001A
    0.001A*.7Ω = .0007V
    .0007V x 71 = .049V = 49milliVolts
    If your ADC is only 8 bit, and your reference voltage is 5v, you can pick out steps of 19 or 20 mV. That's a little more than twice the resolution you are asking for. If your ADC has 10 bit resolution, all the better.
  12. umer27
    Feb 28, 2009
    25
    No, I want to be able to measure currents from 0 to 1 Amp with a resolution of 1-2mA ...
    My initial resistor is/was 0.1 Ohm.. 3 Watts (wire wound) ...
  13. umer27
    Feb 28, 2009
    25
    so i guess... initially I had thought.. of a 0.1 ohm resistor in my 1st post..
    1mA=0.001 A
    0.001A * 0.1 Ohm = 0.0001V
    0.0001V x 71 = 0.0071V or 7.1mV ... thats inviting noise to destroy my readings..
    I think the resistor should be in the range of 0.8 to 1 Ohm..
