measuring ttl frequency (beginner)
Discussion in 'General Electronics Chat' started by danilo mello, Sep 10, 2012.
  1. danilo mello
    Sep 10, 2012
    Hello
    My problem is : i need to build something that reads a TTL signal and write the average frequency to a serial port every specific time. Simples as that. (frequency of about 500kHz and sampling every 0,1s)
    I was using an arduino board to do the job, but it is not working quite well, so, i started looking for more specific hardware to help me do the job, like counters, flip-flops, etc etc.
    Some people say that i should learn assembly to help me with this, others say that i must learn PIC, others suggest me buying this, that, etc etc.
    well. can someone point me a path i should follow? im tipically self taught, so, i just need a tip to know where should i look for to solve my problem.
    Thanks.
  2. Dodgydave
    Jun 22, 2012
    5,156
    772
  3. Papabravo
    Feb 24, 2006
    10,340
    1,850
    You can actually do it with anything, but there are limitations with every solution. The instrument you want is called a frequency counter. When trying to build something it helps to have something to compare your results to. If you can find a build it yourself kit that would be a good place to start.
  4. ErnieM
    Apr 24, 2011
    7,439
    1,627
    Way cheaper then a frequency counter is a frequency generator. You can buy a complete TTL output oscillator for a few dollars, and they are incredibly accurate.
    Having a known source will let you compare what your circuit is doing.
    While I have never worked with an Arduino I would be very surprised if it was not capable of doing this task.
  5. MrChips
    Oct 2, 2009
    12,638
    3,456
    Here are three ways to build a frequency counter
    1. Build from TTL or CMOS counters and gates.
    2. Use a single chip frequency counter such as ICM7208 (if you can find one)
    3. Use a microcontroller
