Measuring temperature
Discussion in 'General Electronics Chat' started by cranker, Dec 25, 2010.
  1. cranker
    Dec 25, 2010
    how to use AD595 and icl7135 to measure high temperature
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
  3. SgtWookie
    Jul 17, 2007
    22,183
    1,728
  4. nickagian
    Mar 12, 2010
    34
    Hi!
    Why don't you explain a little bit what your problem is? Have you designed any draft schematic and want any help on it? What temperature range do you want to measure?
    Very briefly, the AD595 is used as a front-end for measuring temperature with thermocouples. So you need to connect a thermocouple to AD595 and take an analogue voltage that changes when temperature changes from pins 8,9. Look at figure 1 at the datasheet of AD595. Then, this analogue output voltage of the AD595 (which represents temperature) can be displayed in an LCD display by using the ICL7135. That's the general idea I guess.
    Nick
