Measuring temperature on pt100
okin
Joined May 9, 2010
12
Hi all,
I have 2 resistor like on schematic and I want to measure measuring temperature on Pt100. Trough resistors flow constant current of 0.5mA. I want to amplify voltage drop on pt100 and connect that on ADC. What is the best way to amplify a little voltage change on pt100 ?
retched
Joined Dec 5, 2009
5,207
An op amp or instrumental amplifier will increase the minute changes to more manageable changes.
What are you trying to measure? (Object and temperatures) This may not be the best for the job.
okin
Joined May 9, 2010
12
t06afre
Joined May 11, 2009
5,934
Is this like a school project and you have to use a PT100 element, or can you use other solutions. Do not be afraid to say this is a school project. Everyone is entitled to help in this forum
If you are using a microcontroller, then also consider digital solutions like the TMP100 or TMP112. Accurate and easy, just need to do SPI communications.
okin
Joined May 9, 2010
12
Yes, I must use pt100. But thanks everyone for other advice
