Measuring surface tension
Discussion in 'Physics' started by boks, Feb 8, 2009.
  1. boks
    Thread Starter Active Member
    Oct 10, 2008
    218
    To meaure the surface tension of a liquid, a rod of r = 1 mm radius and l = 1 cm length is dipped horizontally into the liquid (see figure). The force required to pull the rod out of the completely wetting liquid is measured to be 0,49 mN. What is the surface tension of the liquid?
    <br />
\gamma = \frac{F}{P \cdot cos(\theta)}<br />
    This formula can be applied to the Wilhemly Plate Technique for measuring surface tension. When a rectangular plate having length l and thickness t is submerged, P, the perimeter of the plate, is 2(l + t). When ithe submerged item is a rod, is it reasonable to assume P = 2(2r + l), i.e. the liquid surrounds half the surface area while the rod is being pulled out?
  2. mik3
    Feb 4, 2008
    4,846
    63
    The perimeter of a rectangle is 2(l+w)
    where
    l=length
    w=width
    State your problem more clearly.
    Are you trying to find the surface submerged into the liquid?
    Is this surface includes the bottom side of the rod or just the side surface?
  3. studiot
    Nov 9, 2007
    5,005
    515
    I remember this one from my GCE practical exam in the 1960s
    We had to float a needle on the surface of a dish of water , then drag the needle up the meniscus with a magnet, balancing the surface tension against the magnetic force to measure the tension.
  4. boks
    Oct 10, 2008
    218
    The problem is stated in its original form. I forgot to add an illustration, now it's done.
    I'm trying to find the surface tension. I'm familiar with problems of this kind where the submerged item is a Wilhelmy plate. Then P = 2(l + t) where l is the length and t is the thickness. This is the perimeter of the cross section between the plate and the liquid. The cross section isn't that obvious - at least not to me - when the plate is replaced by a rod.
    Assuming P = 2(1cm + 0.2 cm) = 2.4 cm, I get
    <br />
\gamma = \frac{0.49 mN}{2.4 cm \cdot cos(0)}=20.4 mN/m<br />
  5. mik3
    Feb 4, 2008
    4,846
    63
    If it is the perimeter of the cross section, ie around the plate, then for the rod the perimeter is 2*pi*R.
