Measuring skin conductance
Discussion in 'The Projects Forum' started by Johnny1010, Nov 4, 2015.
  1. Johnny1010
    Jul 13, 2014
    83
    Hi everyone!
    I am trying to measure the skin conductance, for that I found this circuit online.
    So from it what I have understood so far:
    - There is a low pass active filter at first stage with cut off of 1.6 Hz and variable gain.
    - The second stage is also a filter with unity gain and is biased at half the voltage supply and the first stage is biased at the output of second.
    What I don't understand:
    - Why is the gain variable at first stage as the Rskin chages the gain would change?
    - Isn't the first stage enough?
    - Can't understand the biasing of the op-amps as well.
  2. Johnny1010
    Jul 13, 2014
    83
    Guys please help me out!!
  3. Alec_t
    Sep 17, 2013
    5,968
    1,135
    I think the circuit is intended to be an oscillator comprising two integrator stages in a loop, with an oscillation frequency dependent on Rskin. Spice simulation says it doesn't oscillate.
  4. Johnny1010
    Jul 13, 2014
    83
    This has got me more confused.
