Hi when i measure sine wave of 60hz from adc pin, it gives different values everytime. Obviously its amplitude is varying. But how to measure average value of it.
If it varies with every measurement you are probably doing it right.Hi when i measure sine wave of 60hz from adc pin, it gives different values everytime. Obviously its amplitude is varying. But how to measure average value of it.
I haven't used that method MrChips and would like to see your procedure if you don't mind showing juts an outline of what is involved.You don't have to record the highs and lows of the sine wave. You can perform a least-squares fit to a sine wave and estimate the amplitude.
function [params,yest,yres,rmserr] = sinefit(yin,t,f,verbose,plotflag)
% params = sinefit(yin,t,f)
% [params,yest] = sinefit(yin,t,f)
% [params,yest] = sinefit(yin,t,f,verbose)
% [params,yest] = sinefit(yin,t,f,verbose,plotflag)
% [params,yest,yres] = sinefit(yin,t,...)
% [params,yest,yres,rmserr] = sinefit(yin,t,...)
% Least squares sinusoid fit - optimization toolbox not needed
% IEEE Standard for Digitizing Waveform Recorders (IEEE Std 1057):
% Algorithm for three-parameter (known frequency) and four-parameter
% (general use) least squares fit to sinewave data using matrix operations.
% INPUTS: -yin: Input signal to be fitted (a vector)
% -t: Time vector (same length as yin)
% -f: Signal frequency (actual or estimate) [Hz]
% -verbose: if 1, display information; else, don't. default: 0
% -plotflag: If 1, plot; else, don't. default: 0. The plots are:
% time-domain plot, histograms and modulo-time plot.
% Modulo-time plot is copied from file ID: #22907
% -The time vector is not necessarily linearly spaced (hence required here)
% -If f is a guess, it has to be near true input signal frequency
% OUTPUTS: -params: A vector containing:
% [offset amplitude freq(Hz) angle(rad)].
% If not converged, params = [nan nan nan nan]
% -yest: Estimated sinusoid:
% offset+amplitude*cos(2*pi*frequency_Hz*t+angle_rad
% -yres: The residual
% -rmserr: Root mean square of the residual
% 4-parameter sinefit uses 3-parameter sinefit to create initial search
% vector. For further information, consult IEEE Std 1057 and/or
% IEEE Std 1241 documentation.
% type sinefit for demo
% convergence related things you can tweak:
TOL = 2.2204e-016; % Normalized initial tolerance (default: eps )
MTOL = 4; % TOL relaxation multiplicand, MTOL > 1
MAX_FUN= 16; % MAX number of function calls
MAX_ITER = 32; % MAX number of iterations in one function call
% Convergence related stuff: Vector x0 will be created: x0=[A B C dw],
% where A & B are sin & cos multiplicands, C is the offset and dw is
% the angular frequency increment in iterative search.
% x0 is, of course, normalized in convergence calculation
%(Fit for 1*yin converges as fast as for 100*yin)
% **** if max(abs(x0(i)-x0(i-1)))<TOL, the fit is complete.
% **** if not, multiply TOL with MTOL and retry maximum of MAX_FUN times.
%plotting related
if nargin == 5
if plotflag
N_per=8; %number of periods plotted
N_hist = 11; %number of bins in histogram
end
else
plotflag = 0;
end
if nargin == 0 %demo
fprintf('\ndemo: creating sinusoid with\n\t- clock jitter,\n\t')
fprintf('- phase noise,\n\t- additive noise and \n\t- harmonics\n ')
N=pow2(11); %vector length
fs = pi*1e3; %sampling freq
ts = 1/fs; %sampling interval
freq = (N/128-1)*fs/N; %freq (Hz)
phase = -pi/8; %phase (rad)
offset = pi*4; %offset (i.e mean)
amplitude = pi/3; %amplitude
t = (0:(N-1))*ts; %time vector
std_jitter = 1e-2; %standard deviation of jitter noise
std_addnoi = 1e-1; %standard deviation of noise added to signal
std_phase = 1e-2; %standard deviation of phase noise
noise = randn(1,N);
std1_noise = noise/std(noise); % random vector with stdev = 1
jit_noise = std_jitter*std1_noise;
phase_noise = std_phase*std1_noise;
add_noise = std_addnoi*std1_noise;
w=2*pi*freq;
t = t + ts*jit_noise; % add clock jitter
A2 = amplitude*0.01; % 2. harmonic ampl
A3 = amplitude*0.02; % 3. harmonic ampl
yin = cos(w*t+phase+phase_noise); % sinusoid with phase noise
%add offset, noise & harmonics
yin = offset+amplitude*yin+A2*yin.*yin+A3*yin.*yin.*yin+add_noise;
figure
params = sinefit(yin,t,freq,1,1);
fprintf('\n\t\t\tpure sinusoid\tnoisy sinusoid fit')
fprintf('\nOffset: \t%3.4g\t\t\t%3.4g',offset,params(1))
fprintf('\nAmpl: \t%3.4g\t\t\t%3.4g',amplitude,params(2))
fprintf('\nFreq: \t%3.4g\t\t\t%3.4g [Hz]',freq,params(3))
fprintf('\nPhase:\t\t%3.4g*pi\t\t%3.4g*pi [rad]\n',phase/pi,...
params(4)/pi)
fprintf('\nend demo\n')
clear params yest
return
end %end demo
if nargin < 4
verbose = 0;
end
if verbose
tic
end
%vector dimension preps
[rc]=size(yin);
if rc(1)==1
yin = yin(:);
N=rc(2);
else
N=rc(1);
end
t=t(:);
onevec = ones(N,1);
%t does not have to be linearly spaced, so to estimate sampling time ts
ts = rms(diff(t),N-1); % ts needed in freq normalization of converg. calc
if MTOL<0
error('MTOL is a positive number > 1')
elseif MTOL<1
MTOL=1/MTOL;
fprintf('warning: MTOL should be > 1,')
fprintf('swiching to inverse value.\nXTOL = %i\n',MTOL)
end
% convergence related normalization
rmsyin = rms(yin,N);
TOL=rmsyin*TOL;
%here we go
[x0,iter] = sinefit4par(yin,t,ts,2*pi*f,onevec,TOL,MAX_ITER);
iter_total=iter;
iter_sinefit4par = 1; %first function call
%success?
if iter<=MAX_ITER
success = 1;
if verbose
st1 = ['\n\tConverged after ' int2str(iter) ' iterations\n'];
fprintf(st1)
end
else
if verbose
st2 = '\n\tincreasing TOL...';
fprintf(st2)
end
while iter>MAX_ITER && iter_sinefit4par<=MAX_FUN
if verbose
fprintf('.')
end
%while # of function calls is < MAX_FUN, do:
TOL = TOL*MTOL; %increase TOL
iter_total = iter_total+iter;
iter_sinefit4par=iter_sinefit4par+1;
end
if iter>MAX_ITER
clc
fprintf(['\nFailed to fit. The reasons could be:\n\t1. Bad ',...
'initial guess for frequency OR\n\t2. ',...
'the amplitude level is way below RMS noise floor OR',...
'\n\t3. too small MAX_FUN, FUN_ITER, MTOL or TOL.\n\n'])
fprintf(['%g function calls made, %g iterations allowed ',...
'in each.\n\n'],iter_sinefit4par-1,MAX_ITER)
success = 0;
%return
else
success = 1;
if verbose
st1 = 'converged!\n';
fprintf(st1)
fprintf(['\t%g function calls made,\n\t%g iterations allowed ',...
'in each.\n\n'],iter_sinefit4par,MAX_ITER)
end
end
end
%prep the output parameters
A0=x0(1); B0=x0(2);
C0=x0(3); w=x0(4);
A=sqrt(A0*A0+B0*B0);
phi=atan(-B0/A0);
if A0<0
phi=phi+pi;
end
f_est=w/(2*pi);
params = [C0 A f_est phi];
yest = x0(3) + x0(1)*cos(x0(4)*t) + x0(2)*sin(x0(4)*t);
yres = yin-yest;
rmserr = rms(yres,N);
if verbose
t_elapsed=toc;
if t_elapsed<60
fprintf('\tTime elapsed: %g seconds\n',t_elapsed)
else
% this is not likely to happen
fprintf('\tTime elapsed: %g minutes and %g seconds\n',...
floor(t_elapsed/60),rem(t_elapsed,60))
end
if plotflag
fprintf('\nplotting...')
end
end
%plot or not
if nargin == 5
if plotflag == 1
plotsinefit(N_hist,N_per,t,ts,yin,yest,yres,f_est,N,verbose)
end
end
if not(success)
params = [nan nan nan nan];
yest=nan; yres=nan; rmserr=nan;
end
%preserve the original vector dimensions
if nargout > 1
if rc(1)==1
yest = yest.';
yres = yres.';
end
end
function x0 = sinefit3par(yin,wt,onevec)
%3-parameter fit is used to create an initiall guess in sinefit4par
cosvec=cos(wt);
sinvec=sin(wt);
D0=[cosvec sinvec onevec];
%x0=inv(D0.'*D0)*(D0.'*yin);
[Q,R] = qr(D0,0);
x0 = R\(Q.'*yin);
%x0=lscov(D0,yin);
function [x0,iter] = sinefit4par(yin,t,ts,w,onevec,TOL,MAX_ITER)
x0 = sinefit3par(yin,w*t,onevec);
x0 = [x0;0];
iter = 0;success = 0;
while success == 0
w=w+x0(4);
wt=w*t;
cosvec=cos(wt);
sinvec=sin(wt);
D0=[cosvec sinvec onevec -x0(1)*t.*sinvec+x0(2)*t.*cosvec];
x0old = x0;
[Q,R] = qr(D0,0);
x0 = R\(Q.'*yin);
%x0=lscov(D0,yin);
iter = iter + 1;
%error term with dw normalized
temp=abs(x0-x0old).*[1 1 1 ts].';
err=max(temp);
if err<TOL || iter > MAX_ITER %if iter>MAX_ITER, increase TOL and
success = 1; %re-visit this function later.
end
end
x0(end)=w; %place w in the position if w's increment
function plotsinefit(N_hist,N_per,t,ts,yin,yest,yres,f,N,verbose)
% function deleted in order to keep post within character limits
