I'm chewing through a tough problem, and wanted to know if anyone could shoot down or confirm a few ideas I've been bouncing around, and help out with their experience.
I have two cylinders with the top face of one connected to the bottom face of the other. The cylinders can spin about the Z axis (think two cans, stacked one on top of the other, spinning the top can). Is there any way to measure the relative rotation of one to the other with +-.005 degree precision? The cylinders will not spin more than +-5 degrees relative to one another. The system has to be mounted to the side of each can, however there may not be anything rigid between them (they should be able to rotate freely), so 'soft' strain gauges are ok, metal braces with potentiometers are not.
Ideas I've had so far:
Gyroscopes paired with accelerometer to make an IMU
Electronic compasses (difference between magnetic norths)
Inclinometer (?)
Fiber Optic Gyroscopes
Inclinometer (?)
